2006 E500 - Service D
Display reads that Service D is past due 90 days ... (the car was lease return end of June ... Auctioned in Oct ... and Dealer had it since beginning Nov ..
First thing I did was change Oil ... looked really dark .. will send it in for an analysis .. (yeah . maybe I should have done this before purchasing???)
Now ... additionally the items listed in FSS are 2,4,9,12 and 14
Via Maintenance booklet all look about right (either 2 years or 26,000) . but item 2???? That's supposed to be at 52K miles ??? Why is it showing up now in FSS? ... I don't want to think it .. but has the odometer been tampered with?
I would assume it probably got its first service on time, but was late on the second service time-wise, but not mileage wise.
2 4 9 12 14
Additional Items ...
1 2 4 5 6 7 8 9 10 20
I don't even see a 20 in the maintenance manual ...
Also current mileage is 19,279 .. The FSS reads service in ..
+5,380 miles
- 93 Days
Shouldn't current mileage and FSS due mileage add up to 26,000?
If it were my car, I would not be concerned with it and just perform the services - that way you know what you are starting from.
Mercedes has changed their services to only encompass A and B services. They do not go by the D, E, etc and longer.
In the engine compartment the plastic engine cover .. air filter housing has what appears to be a yellowish junk around the seams .. is this common for the 500's?
As for codes .. yes. I was planning to take it down to dealer .. get brake fluid flushed .. I like to work on my cars ... always have just don't have that much time anymore ... so aside from oil change and filters .. etc I'll let dealer handle the rest .. unless I find a good MB indy in jersey
I think it's a good idea to have the dealer do it. And depending on your dealer, you can drive a new MB while they are working on it (as a loaner).
The only extra advice I would offer is to check to see what motor oil your dealer uses, many dealers vary, and all oils are not created equal.
http://www.whnet.com/4x4/oil.html
If you are from Jersey, I would use the 0W40 oil for winter, perhaps the dealer only had 5W40 oil that is approved for diesels too (229.51)?
From the link you should find both 0W and 5W oil types for an AMG engine, although quite many are not approved for AMG.
You need to use a 229.5 oil, so M1 0w-40 is the correct one if you want a mobil product.
