- Mercedes-Benz E-Class: Warning Lights
Important information to help you understand your Mercedes-Benz
Red battery message ( Visit workshop)
I checked the Aux Battery and it read 8.5 volts so time for another replacement. I shopped the internet to find a fully sealed and fully charged battery with at least a 1 year warranty. I located a YTX14-BS AGM Maintenance Free Battery at batterymart.com for $55.95 with free shipping. Just to be sure the battery was an exact 14-BS fit I called the company to verify. The support person I spoke to was surprised to find out that I needed the battery for a Mercedes but after discussion we decided it was a fit.
The company is located in VA and their support person told me that it would ship that afternoon via FedEx and I should have it in NJ the next day or 2 at most. I received the battery the next day to my surprise.
Th battery is an exact fit dimension-wise. The battery comes with two nuts and bolts. Use the nuts (metric - perfect fit) in the terminal slots (which are different than the OEM posts) to secure the original battery cable bolts following the nice detail instructions in an earlier post. As a side note, I looked at many batteries and could not find any that had the same terminals as the OEM battery.
The battery has been in for a month now and everything is still working fine. I'd recommend checking out Battery Mart if you're shopping around.
Just make sure it is an AGM battery.. I had some weird issues happening all because of a non-AGM battery being put in my car..
According to batterymart.com, the YTX14-BS is an AGM battery and a Chinese made one. They said the terminals of this battery are non-threaded not like the Mercedes OEM auxiliary battery (FIAMM):
[Non-threaded terminal of YTX14-BS]
They said that below battery is an American made version and preferred
http://www.batterymart.com/p-Big-Cra...4-Battery.html
According to them, the terminals of this American version have threaded inserts cast inside, so the terminal accepts the bolt. They have installed a few of this battery for Mercedes in their retail locations.
[Threaded terminal of ETX14]
Last edited by astrobike; Jun 28, 2013 at 02:57 PM. Reason: to add more information
Congrats on solving the issue, novae500!
How much did it cost to replace the alternator?
Hi if any body can help me plz. i recently bought 03 E220 with 65000 miles.last week i had red battery msg but it disappeared once it do a small journey.comes in twice a week but disappear itself once i switch off the car andrestart the car. Rear batty is new only 6month old what that could be now.
thanks
thanks
Can anybody give done idea what needs to be done ? My local MB dealer is also confused and has still not diagnosed the fault. He made me change both batteries and BCM but still the red warning is there !
1.battery(visit Wksp ) 2.brakes service 3.SRS 4. Right turn indicator
Brakes : turned out the SBC needs replacement as it has "reached end of service life" . Battery: we are unable to get rid of red warning despite changing both batteries and BCM . Now as per your suggestion I will check both new batteries again
However after the car was parked for one hour after a short drive it came back. Then after I drove for few mikes it again disappeared. I guess the new aux battery needs charging by car's system.
What do you think, VETTDVR ? Anyone ?
I suspect you need more run time to charge. I would just drive it a week or so and see if the light stays off. IF not run a charging system check.
I have had the Red warning since a month or so, and believe me, the MB dealership is exactly like HDL cholesterol - will kill you slowly.
I got the courage after reading vettdr's posts' suggestions and advice.
From the posts I was sure I needed the aux battery replaced but kept imagining worst-case scenarios if something went wrong.
I am in Toronto, an excellent location for cold-stress-testing of hearts and batteries. Whilst searching for a suitable (best) aux battery, I parked my 2006 E350 4matic wagon overnight in the open during the ice storm that caused a week-long power outage. When the storm abated, the car would not start. Again, having studied the posts here, I knew it was the main battery, in the trunk, that died. I called CAA (Canadian equivalent of AAA) and the battery was jump started. The guy said he did not have the type I need as it is a "very sturdy and special battery, unlike the Chinese makes used in far lighter Japanese and cheap American cars".
The car started up and I drove 2 hours, then parked it in the apartment's underground.
After 3 days, another no-start. Major wake-up call, so I started researching on main batteries. To my luck, Canadian Tire has a new line of Motomaster Eliminator Ultra AGM on discount, and with a full 5 year replacement warranty and roadside assistance.
I paid $100 as installation fee as it is still too cold and I don't have a garage. It works excellently.
I continued my search for the aux battery and discovered that supply is extremely limited as it is a motorcycle battery and the riders seem in hibernation.
Best I could get was Exide AGM with a 6 month warranty, for $ 69.95 which is no good. So I called the MB dealer and they charge $ 149.65 for the original Fiamm. I bought it precharged and just installed it. It was SUPER EASY to replace and my dash no longer looks like the Warcraft video game screen when you have been shot.
I did not disconnect the main battery, but I was fulyt alert so as to avoid shorting the live terminals. I used small plastics bags to shroud the cable ends.
I'll try and post images. Hope it helps . . .
References to the pics:
Fig. 1 & 2:
After having replaced the main battery, the Red Battery Alert still remained.
Bought the Fiamm 12V / 12AH / 170A aux. battery from MB Thornhill (Green Ln) on Feb. 18, 2014 for $149.65 + $19.45 HST = $169.10
Fig 3:Date of manufacture: week of Sep 29 -- Oct.05, 2013
Fig 4:
Fig 6:
Fig 7:
