Help..In Dash 6 Disc Changer Door (W211) Will Not Go Up
Warranty resolve have the dealer update the COMAND head unit software per DTB P-B-82.60/382b AUG07. If not under warranty, DIY - purchase service disc (special tool) W211589142200 as procedure to update is simple. If equipped with navigation and phone the update will add ETA + telephone signal strength to display, and navigation voice mutes with MUTE button.
Since you do not mention the model year, if your vehicle is equipped with Audio50 head unit (cassette player) DTB P-B-82.62/226c (disc W211589122200) will apply.
PM your email address and I will forward a copy of the relevant DTB inclusive of update procedure.
Any help will be appreciated.
The motor is not available separately. Housing inclusive of motor for your vehicle is part #2116800552 (for comparison pricing, parts.com $98.90). PM your email address and I will forward install instruction sheets to assist in repair or replacement.
Will try to check fuses in few hours.
do the parts.com ship worldwide?
in our shops price for this unit is 153$, and shipment for 25 days!
2Clinton Horn
Nice story)
Sorry, i cant help you unless you wan to buy the above unit...
I have retrofitted NTG2.5 and had NTG1 before. Now door wont open. I know problem is at Comand. Have anyone found solution to made it work with NTG2.5? Do anyone have wiring diagram for that door and is it 12V motor for that?
I bought a VIM module that allowed me to watch video and allowed the door
to work again.
With the module it will allow VIM but the navigation won't work because it is fooling the velocity reading to show that the car is not in motion.
I have buy NTG1 to NTG2.5 harness there.. Haft to ask them more..
teamwork
teamworkLoads of similar issues but few solutions other than to either remove the fuse or change the unit.
I bought a 2003 W211 Estate a few weeks ago and had the same 'not opening' issue, until today. I could hear the motor working but no visible action.
The repair in my case was free, needed only a TT20 Torx and took less than 20 minutes:
- Shifter to Drive
- remove ashtray
- remove ashtray housing
- remove gearshift surround
- remove two black CD changer housing screws (TT20), disconnect cables and remove unit
- turn unit over and remove two silver open/close motor screws (TT20)
Now, the winner:
- look at arm that connects gear on motor to Changer unit. in my case, there is a locator that was out of position, probably a failsafe to prevent greater more costly damage.
- remove and refit the locator then reassemble and reinstall in the car.
Problem solved!
- Shifter to Drive
- remove ashtray
Now, the winner:
Problem solved!
Tks
