Mercedes battery trickle charger
Is it safe to trickle charge the battery on the W211?
Couple years back, I had purchased a MB trickle charger. Consistently used it on my SLK since that car is used infrequently.
I was wondering whether I can safely trickle charge the main battery on the W211.
Any thoughts? Also, since the main battery is in the trunk area 'buried somewhere', are there areas in the engine compartment area I can attach the trickle charger to for charging the battery?
Many thanks in advance
I have used these in all my cars for years.
Steve
Steve
Grnhilndr_2
Is your Interstate the type of maintenance free battery that allows you to remove caps and add water ? If that's the case, there's your source of the acid.
Steve
Is there anyway I can trickle charge the main battery (rear battery) w/o accessing the back. I was thinking of opening the hood and attach the crocodile clips to Positive and Negative Posts within the engine compartment to charge the battery.
OLD thread but this is what I want to do but have to ask do you have to keep your trunk open the entire time? As soon as I pop the trunk it goes upright, unlike my STi or wife's Toyota where if I pop the trunk it's only opened a small inch or two. This makes it not practical at all when I have a car cover on it.
Thanks,
-Nigel
cashwowud
