E-Class (W211) 2003-2009
recommnded engine oil
Old Feb 15, 2009 | 05:09 PM
leshoiad's Avatar
E220 w211
Hi guys,
so i'm new one with mercedes w211, it's E220. I'v wondering what kind of oil is recommended by manufacturer for my engine. It's a disel engine. Thank u in advance.
Old Feb 15, 2009 | 05:28 PM
Untertürkheim's Avatar
What year is the car, it will determine if you need 229.3 or 229.5
Also, it depends on whether or not you have DPF, that will determine if it is 229.5 or 229.51
Without DPF, 229.3/5, like Liqui Moly Diesel Synthoil (229.3) or Synthoil High Tech 229.5
With DPF, 229.51, like Castrol EDGE Formula RS
The above oils are available in Germany, but if you tell us where you are, you should get more tailored responses.
Old Feb 16, 2009 | 12:45 AM
leshoiad's Avatar
E220 w211
So the car is 09.2004 made. I'm from Bulgaria. And what means DPF and other numbers. This cuestions are stupid may be but.................till this momment i've been drive only gasoline cars. Yes we have Liqui Moly products here but i'm not shore exactly about this u menshed. Actually my question was about make of oil and numbers backside 10W40 for axample. Thank you!!!
Old Feb 16, 2009 | 02:36 AM
The make of the oil and those numbers are not important. You must use oil with a 229.51 approval from MB if your car has a particle filter (DPF), without particle filter, 229.5. This number will be on the bottle somewhere.
If you would like, send me the identification number of the car and I can tell you if it has a particle filter.
Old Feb 16, 2009 | 05:06 AM
leshoiad's Avatar
E220 w211
So the tipe of oil depends from this DPF filter number, right? It's some kind of catalyst as gasoline engine, isn't it? It's a pity but i couldn't give you the number of DPF right now!!! What obout in general? Is the oil depends from the weather season or................? Thank you!!!
Old Feb 16, 2009 | 05:07 AM
leshoiad's Avatar
E220 w211
And identification number, you mean VIN number, do you?
Old Feb 16, 2009 | 05:15 AM
The DPF does not have a number, I asked for the VIN because I could determine from that wheter or not your car is equipped with a DPF.
If you have a DPF, you need the 229.51 oil , the 1 at the end indicates the oil is low in additives that could damage the filter.
If the car does not have DPF, you can use 229.5 oil.
Yes.
Old Feb 16, 2009 | 08:19 AM
ohlord's Avatar
2004
E220 any mb spec oil that meets 229.31 mb spec 0-30wt. or 5w30 wt. 0w40
5w40
shell,mobil,fuchs,what ever you have that meets that spec.
Old Feb 16, 2009 | 12:05 PM
5w40
Remember, his car was built in September of 2004, making it what we would call a 2005 model. This is why I said 229.51
