E-Class (W211) 2003-2009
REMOTE WINDOWS
Old Mar 21, 2009 | 10:53 AM
MANOS75's Avatar
e350
REMOTE WINDOWS
I HAVE AN 06 E350 SOPTRS AND AND APPEARANCE PACKAGE, MOST OF THE TIME ALMOST ALWAYS WHEN I WANT TO OPEN OR CLOSE WINDOWS WITH THE REMOTE IT DOES NOT WORK NO MATTER HOW CLOSE TO THE SENSOR I GET, HAS ANYONE ELSE HAD THIS PROBLEM AND IF SO ANY SOLUTIONS
Old Mar 21, 2009 | 11:19 AM
Roehl's Avatar
2004 MB E-500 & 2000 Honda Accord Coupe
try so synchronize all your windows and sunroof or your remote door handle sensor might be dead. The dealer replaced mine a few years back.
Old Mar 21, 2009 | 12:12 PM
Barry45RPM's Avatar
2015 ML 350
I had that problem in my '04... sometimes the windows would even stop half way. Sometimes it worked fine inside the service department. They had to replace the IR sensor door handle, and then it worked fine inside or out.
Old Mar 22, 2009 | 07:56 PM
tashakes's Avatar
2020 GLE350
Mine will not work from the front, only from the side as long as the key is pointing to the door handle. This is a pain, I always back in my car onto my parking spot at my office and if it starts raining and my roof is tilted up I still have to run outside and get wet in order to close it. There should be a sensor on the front, but I guess there is not one....
Old Mar 22, 2009 | 08:17 PM
onthewall01's Avatar
2007 E350 Sport
Do all cars have this capability? How do you do this?
Old Mar 22, 2009 | 08:36 PM
Dema's Avatar
i535
It is a small IR sensor in door handles, you need to point your FOB IR directly to door handle and hold open/close button to operate windows.
Old Mar 22, 2009 | 11:41 PM
Barry45RPM's Avatar
2015 ML 350
Drrivers door only after '03. Point key towards the little red window on the door handle, press & hold Unlock Button to roll down windows/sunroof.
The car unlocks via radio waves, the window comand is sent via Infra red light (like a TV Remote).
Old Mar 22, 2009 | 11:50 PM
2007 E350 Sport
Can I use this to close the windows as well? Maybe hold down the lock button?
Old Mar 23, 2009 | 12:55 AM
Roehl's Avatar
Yes. You can open and close the windows/sunroof with the remote. Too bad you have to point it to the door handle just to make it work. On the Audi you can do the same function as far as your arm/disarm the door. Why does it have to be IR?
Old Mar 23, 2009 | 02:12 AM
Diesel Benz's Avatar
This feature actually exists on older cars too, at least the W210 had it.
MB feels it being a safety issue that you can only operate windows when close to the car, you cannot "accidentally" close windows then. One may not consider this reasonable but MB often selects a safer option even if it brings a drawback in some other aspect.
And of course the user manual explains how to use it for those who want to know.
Old Mar 25, 2009 | 03:51 PM
CLEK500's Avatar
CLK500, E500, SC400
Wrong, it work with w208, w210, W163 too, cuz i owned those cars before.
It's a standard feature,both of my CLK500 and E500 work with 8ft range. Especially watching my CLk folding down the top with the remote, it's cool
Old Mar 25, 2009 | 04:18 PM
Barry45RPM's Avatar
2015 ML 350
What about the quote wrong? It uses IR to operate the windows on the 211and there is no door handle IR window on the 211 after the 2003 model year. Stand by the passenger door & try it. The windows will not move but the doors will unlock on 211's after 2003.
Old Mar 25, 2009 | 10:47 PM
Mackhack's Avatar
Edward,
you could use a DAS and get the feature enabled that your sun roof closes automatically as soon as the rain sensor senses rain.
Old Mar 25, 2009 | 11:15 PM
n0n0tme's Avatar
2005 E500
Try replacing the remote battery, I noticed on mine when the battery is old it is harder to open or close the windows. I also had this feature on my old w202.
Old Mar 28, 2009 | 02:20 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
These sensors are prone to go bad in the driver side door. Also, if the handle was waxed, it can damage the lens on the sensor. If new batteries do not work and the I/R window is clean and not damaged, you probably need a new I/R sensor.
It should work from 10 feet away, pointing at the driver door handle with the SmartKey.
Previous generation cars (W210, etc) had I/R sensors on the passenger side as well.
Old Mar 28, 2009 | 02:21 AM
Polar Bear's Avatar
Originally Posted by Mackhack
Edward,
This will not accomplish what he is trying to do. The rain-close feature will only vent the roof (if it were open) - not close it. He stated it was already vented and he wanted to close it.
Old Mar 28, 2009 | 02:36 AM
Mackhack's Avatar
So the sun roof will not completely close but rather tilt upward? That doesn't make sense but I believe you of course.
Old Mar 28, 2009 | 03:25 AM
Polar Bear's Avatar
Correct. If the roof is open, it will close the roof, and place it in the vented position if it detects rain. The same thing with excessive interior heat it is detected - it will vent the roof. I don't see a need for that and would worry if my car sat outside on a hot day, the sunroof would automatically vent and if it came a rainstorm it would get the inside of the car wet, so I leave it disabled.
I am not sure why they don't have it close, instead of vent, with the rain-close feature.
Old Mar 28, 2009 | 03:40 AM
Mackhack's Avatar
Question is, would MB respond to that if enough people would make a proactive attempt in writing them with the suggestion of closing the sun roof completely instead of putting it on vent? I mean this should be possible through an update via SDS I assume, right?
Old Mar 28, 2009 | 11:07 AM
Polar Bear's Avatar
Possibly with a flash of the OCP. But I doubt they would change the software for the optimistic 40-50 people that would write them, especially considering it is supposed to be disabled in the USA
Old Mar 28, 2009 | 02:20 PM
Mackhack's Avatar
[...] especially considering it is supposed to be disabled in the USA
That I don't understand. Why in the world do they implement such features but disable them by default? I know cars that are shipped to Dubai for instance have other features enabled/disabled than the US ones or the European ones.
Old Mar 29, 2009 | 01:47 PM
tashakes's Avatar
2020 GLE350
Edward,
Did not know this, it would be such a cool thing to have IF it worked correctly, still cannot understand why it would vent and not just close with rain.
Old Mar 29, 2009 | 10:15 PM
Mackhack's Avatar
See that's what I'm saying. Hm, I think I will talk to Steve once he is in HB next time to enable this feature. I kinda like it. I mean isn't it better to have it tilted rather than all the way open in the RARE case that it will rain down here in San Diego?
Old Mar 30, 2009 | 07:17 AM
sozos's Avatar
e-class brabus k4
if you have the keyless one then press the door button to open them. If not change battery.
