oil tube location help
PS i searched for an hour
http://www.detali.ru/cat/oem_mb2.asp...SGR=005&SGN=01
The tube is back is indeed the trans filler tube. There is no dip stick inside it.
Yup that's it. The transmission is more rectangle with red tang on top with a warning that says "MB workshop". To remove it you break off the red tang push it down through the cap then remove the cap.
For the oil cap on the dip stick tube it will just pull off.
I change oil in my E500 all the time the first times I drained and just refilled with correct fill.
Last time I bought the mityvac and did the job in about 20 min including the filter change. No more crawling under to pull the plug for me on this one.
I have no explanation for my actions except that I was experiencing a "weak" moment that comes more frequently with age. It is an easy job if you pay attention to what you are doing. The cup that houses the filter is much easier to pour oil into than the filler tube. I really never bother with the filler tube unless I am trying to second guess the oil level sensor with my Chinese dipstick.
