rocker arm and camshaft replaced
About two weeks ago my car at sounded louder than usual especially when I was on the gas and getting off of the gas pedal so I bought it in for the advisors to hear the noise. Like usual they say they hear nothing unusual so I then ask them to get the master mechanic to come and hear the noise and he agreed that it sounded much louder than a diesel car which was unusual. He agreed to check the engine out and he notified me that the rocker arms had to replaced along with the camshaft because the shaft was all scored(spelling?).
My question is, is this normal with only 85000km(not miles), and what might have caused this? The did say it was metal fatigue but does this mean that there was improper lubrication in the engine or are there a bad batch of rocker arms and camshafts?
My first guess would be inadequate lubrication (low oil pressure). Sometimes unusual wear is caused by a plugged oil gallery (path) and one would expect this to affect one rocker / cam lobe. If this is a dual cam set up, that hardly seams plausible. In case you are wondering, the idiot light that is now employed in most cars (as opposed to a gage) shows adequate pressure at IDLE. Since operating pressure at speed is considerably higher, there would be no alarm posted as long as the pump can put a few pounds out. I don't blame you for wanting an explanation.
03 E500 and Corvette
Your profile doesn't say which engine or car.? But for any engine to wear out the cam that fast is a problem. It could have been a defective roller in the tappet. OR improper lubrication. Cams are hard on lubricants. If you are using the correct MB oils this should not have happened. Lubrication is one potential cause. If the lobe is damaged completely around I would suspect lubrication. If it is only damaged on the toe I would look at the valve train for sticky valves.(you did replace the rocker). So Rocker could also cause this problem. Hopefully it is corrected and you can drive on. ?? did they pull the engine for the cam work? Is it a dual cam? Did they inspect the other cam, if dual ?
The good news is that I still had six months left on my extended warranty so they covered it since I service the car only at MB and nowhere else that they can blame the problem on. The did say it was metal fatigue which means what?
Metal fatigue is normally from frequent flexing of the material below it's flex limit on a high frequency. This could be due to an incorrect mix on the foundry steel making. The cam might have been incorrect material or not heat treated correctly to prevent the damage.
Rocker arm noise (tikking)
about 4 months ago i had my rocker arm and cam shaft replaced because the rocker arm was broken and now wen i start my car (2006 E350) i get a tikking noise, sound for about 2-5 seconds then it stops. The car runs good, can anyone tell me whats going on??? Thanks in advance.
Don't worry be happy.
what do you mean wont last??? can this be fixed or should i just leave it alone, the car has 119000 miles. is this why my rocker arm broke ? Thanks for your help
If it is just lifter leak down it should last the life of the engine. Mine has 122,000+ on it and has had a ticking after overnight parking since I bought it in 03, and it still ticks very lightly.
clicking sound-another source
My '09 E350 has a slight but discernible clicking sound at idle (only). The dealer and I have traced the source to the "purge" valve (relay?) located on the driver's side in the engine compartment behind the headlight housing.
I'm told this is typical, but it sure sounds like a bad lifter from days gone by.
relinuca
relinuca
camshaft malfunction
i have a 2007 e 63 amg with 180000 kilomters on it .
everything was running fine until a couple of days ago when I started to here lifter noises from the engine. I went to the dealership and they opened up my engine to tell me that my camshaft was the problem . is this possible ?
how can it be a camshaft? I can understand if it is the lifters but really .....
has anyone heard of something like this ?
i change my oil every 5000 kilometers , also I change my oil filter every 10000 kilometers . I use 0w-40 but is this the right oil ?
they are fixing my ride right now but since I am on a tight budget I will only be fixing the camshaft . is there anything else thatni should change ?
your opinion is very much needed .
If you have the water pump off you might consider a new one if they don't double charge labor and you have 100000 miles on the existing one.
i use mobile one synthetic oil. they told me that they are changing the camshaft only but they are charging me $1800 .
I don't mind the $ 1800 but since I do not have any warranty and I use my car everyday to work , I hope it doesn't break down anymore .
by the way I just had my idle pulley replaced and also I just had all my brake pads and rotor done about to weeks ago .
it has been a very expensive month for me.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
