E-Class (W211) 2003-2009
Replacing rotors not pads?
Old May 8, 2009 | 09:50 PM
akbro93704's Avatar
2014 C250 sport
Our rear brake rotors are warped. This may sound like a stupid question, but can the rotors be replaced without changing the pads? Or are the pads damaged because of the warpage? Thanks.
PS-I would like to change the rotors myself. I know there's a danger more caution is needed because of the SBC system, but I'm hoping it's not too difficult.
Old May 8, 2009 | 11:13 PM
lkchris's Avatar
'10 CL550, '12 GL550
This is ALWAYS forbidden.
Any imperfections on the pad surface that occurred because they adapted to the previous rotor will make hot spots on a new rotor and shorten its life quickly.
Old May 9, 2009 | 12:35 AM
akbro93704's Avatar
2014 C250 sport
Okay, thanks for the info
For those of you that have replaced rotors and pads yourself...where did you order them from? Do you just need rotors and pads, any kind of brake paste or anything?
Old May 9, 2009 | 03:38 AM
CLEK500's Avatar
CLK500, E500, SC400
there is a sticky thread about this on top of this room, check it out
Old May 9, 2009 | 08:20 AM
vettdvr's Avatar
03 E500 and Corvette
Yes you can change rotors and not pads.
But:
You must ask the question why did they warp?
1) Was it due to the pads made with a material/contamination that results in excessive heat?
2) was it due to testing on the track with numerous panic stops.
If it was due to the panic stops maybe you keep the pads. But if you don't really know what caused the warped rotors I would change both.
Old May 9, 2009 | 10:48 AM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
If you want Mercedes OEM parts, one of the best prices I've found is at the MB Dealer, Annapolis, MD: GetMercedesParts.com I just ordered the Dust Filter and the twin Charcoal Cabin Filters for my vehicle from them and the List/Discount prices for these items were $31/$23 and $118/$88. When I previously checked the prices for OEM brake calipers at their Website, they had the lowest price.
Old May 10, 2009 | 11:31 PM
lkchris's Avatar
Screw holding rotor to hub is replaced, not reused.
Bolts holding caliper to hub are replaced, not reused.
You may need a pad wear sensor.
Old May 12, 2009 | 03:29 AM
ohlord's Avatar
If screw
holding rotor is soaked in kroil or other freedom oils and not damaged it can be reused.Bolts holding caliper also reused.Torqued properly you have no need to replace them if not abused in previous r/r's.
www.autohausaz.com has the lowest price this side of my supplier.$22 for rear pads and 2 sensors.
Replace rotors replace pads.....replace pads need not replace rotors if rotors are above min thickness and not gouged.
sbc be sure to disengage the system or lock doors and remove key from area.Follow the diy on the forum or www.alldatadiy.com
Work safe.
Torque the rims properly and you won't have a repeat warping.
Old Dec 5, 2010 | 11:50 AM
jmalek's Avatar
04 E500
If screw
Work safe.
Does alldatadiy.com explain how to change Pads and Rotors for 04 E500?
Old Dec 5, 2010 | 03:05 PM
lkchris's Avatar
Get the service DVD
http://www.startekinfo.com/StarTek/o...tedDocId=11498
