E-Class (W211) 2003-2009
E55 brakes on E500 (fronts)
Old Jul 1, 2009 | 07:49 PM
dacollector's Avatar
13 E350 , 12 BMW 328i
the challenging part of the front is the removal and replacement of the front spindle with the Machined Drilled holes for the AMG Calipers. Once that is installed, the brakes are straight foward like the rears... hear we go....
Here is the Spindles:
With the car on jacks, take off front wheels
Using a 18mm socket, remove the caliper bolts and set caliper on the side
Remove torx screw on rotors, and remove rotors
Using a flat head screwdriver and hammer, remove dust caps at hub to expose the spindle nut
Using a 5mm allen wrench, loosen the allen head screw and undo the nut by hand
Slowly (while holding the front hub bearing ) shimmy the hub towards you and put aside, i took this opportunity to repack the bearings with new grease seals and grease
Remove the three torx screws holding the dust sheild, remove the dust sheild
Using pliers, squeeze the metal band that is on the spindle arm
Using 7mm allen wrench, remove the bolt holding the ABS sensor /speed sensor
This is what you should have
Now the fun part, undoing the ball joints, i use a ball joint seperator on the top 1st, using a 17mm socket to take the nut off
Once it popped, i reassemled it and hand tight the nut so as to support the spindle arm to allow me to undo the bottom three, starting with the steering arm
Now the lower control arms (there are two), once popped, undo the top and it's out
With the space, i took this opportunity to undo the brake line using a 14mm wrench, then installed it on the front AMG caliper and set on the side
Install the new spindle, tighten all 4 ball joints
Cut the dust sheild to allow the larger caliper to mount, once done, use the three torx screw and remount the dust sheild
Old Jul 1, 2009 | 07:56 PM
E55 brakes on E500 (fronts) part 2
Remount the abs/speed sensor, rub some grease on the spindle, slide the hub on the spindle, hand tight the nut, tighten the allen bolt, pound the dust cap on, put brake grease on the hub, mount the new rotor with the torx screw
Using a 21mm socket, mount the AMG caliper
Last but not least, now bleed your brakes free of bubbles, there are 6 nipples, the rears require 8mm wrench, the fronts 11mm wrench, i use a motive presure bleeder, works awesome
Once you are done bleeding, replug in the sbc plug and
Now your done.
Front before:
After:
Rear before:
After:
I hope this helps those that are thinking of doing it themselfs, i just save me 700 - 1000 in labor cost here in hawaii and now it's time to rest..
Old Jul 1, 2009 | 08:50 PM
6hift's Avatar
Great writeup. Where can I get the power bleeder? Kragen?
Are you planning on doing the rears?
Old Jul 1, 2009 | 10:33 PM
thanks,
i went on the motive bleeder website, and fortunately there was a local distributor here in hawaii. also the rears are done and on a different post.
Old Jul 1, 2009 | 11:52 PM
RDSBENZ's Avatar
C300. FJ Cruiser, 370Z
Good job!
Old Jul 2, 2009 | 12:27 AM
155's Avatar
155
R350
Great post! Any pics of your ride?
Old Jul 2, 2009 | 01:31 AM
Scraz51's Avatar
2003 E240
+1 very nice post
Old Jul 2, 2009 | 01:43 AM
sunny_j's Avatar
09 E320 Bluetec
great write up
Old Jul 2, 2009 | 01:49 AM
6hift's Avatar
dacollector,
What do you mean sbc plug?
Old Jul 2, 2009 | 02:26 PM
6hift,
the SBC plug is the plug in the left hand corner of the engine bay. if you look at my first post on "E55 brakes on E500 (rears first)" i posted a picture there as that is the 1st. step before any brake job, and that is to dissable the SBC unit from presurizing the brake system durring dissasembly.
here is the picture of the SBC plug, unpluged. you unplug it by pulling up on the top tab:
Old Jul 2, 2009 | 02:30 PM
hi 6hift, i did the rears 1st. it's on another thread, the rears are easy and is a direct bolt on.. i didn't want to post the whole thing as it would be a very long post..
Old Jul 2, 2009 | 03:05 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Very nice. Looks beautiful.
Old Jul 2, 2009 | 04:40 PM
whatdhizzle's Avatar
Nice write up Thanks.
Old Jul 2, 2009 | 10:26 PM
SurgeSi's Avatar
2005 E
Excellent write up
E55 brakes are what I need to do next.
Looks sexii!
how much did everything run you if its not a secret?
Old Jul 3, 2009 | 01:53 PM
Originally Posted by SurgeSi
Excellent write up
Looks sexii!
contact steve for pricing. tools i spent $35 for the ball joint seperator
Old Jul 7, 2009 | 09:37 AM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Now that is what I call a REAL mod!! Excellent write-up/pics!! Thank you very much and enjoy the car!!
Old Oct 12, 2009 | 12:04 AM
VaderSS's Avatar
'06 E55, W204 C350, '04 Carrera C4S, '02 ML55 (Wife's)
+1 Nice write up! did you have to disconnect the batt as well?
Old Oct 12, 2009 | 09:58 AM
KL2DC's Avatar
W210 E55, W211 E3504M, E90 325i
great writeup! I enjoyed it, thanks!
Old Oct 14, 2009 | 02:41 PM
thanks for the comments.. vader SS no, no battery disconnect on this mod..
Old Jan 5, 2010 | 04:41 PM
155's Avatar
155
R350
Bump...
Does anyone have part #'s for the front AMG front spindles? TIA
Old Jan 7, 2010 | 05:01 PM
155's Avatar
155
R350
Thanks Konigstiger!
E55 steering knuckle (spindle): left 2113306620, right 2113306720 (for comparison shopping, parts.com $292.10 each).
Old Jan 20, 2010 | 11:56 AM
155's Avatar
155
R350
Hi silly question here. Do the e55/63 brakes come with one brake pad sensor or two? My oem brakes have two. The used set of amg brakes I bought only have one. Anyone?
Old Jan 20, 2010 | 02:04 PM
konigstiger's Avatar
'71 Pinto
e63 sensors = 1 front/right, 1 rear/right both part #1715400617.
Old Jan 20, 2010 | 04:36 PM
M-bENZ's Avatar
Corrolla
how hard to do the rear ? is it just plug n play ? you gotta have the big rotor for the rear too right ?
Andy
Old Jan 22, 2010 | 03:20 PM
hey andy, i did the rears 1st . before i did the fronts as i wanted to do the easiest one , then spend time on the hardest part of this mod. i have posted the same step by step for the rears like the fronts.
link:
https://mbworld.org/forums/e-class-w...ars-first.html
