Brake Light Service at 62K - how long can I drive?
Thanks...
Thanks...
No one on this board can tell how far gone your brakes are...
However if your warning is service brakes or Warning SBC failure no one can tell you how long. The problem causing the warning is not known. It might just be you hit a wear indicator in the pads that triggered the alarm but you might have some other problem. Is the brake fluid low? Pads / rotors metal to metal
Changing pads are not a difficult task search on site for info.
vettdvr is right on point. Check out the message board specifically for brakes as well as dialing in on rotors to determine wear level/specs. These steps should guide and provide you with excellent information in how you may want to proceed. Good luck.
What special tools are required besides disarm brake controller?
Thanks....
I ordered may parts (i.e. brakes, plugs, oil filter etc.) from Bekkers Import. May want to contact them to discuss what you are looking for. They should be able to get you squared away.
