E-Class (W211) 2003-2009
option to lower music volume automatically when navi voice gives directions?
Old Aug 1, 2009 | 09:34 AM
DrDrilZ's Avatar
GT3, GTR, 570S
ok i read the manual and searched the forum but couldnt find anything on this. is there an option to lower or mute the radio volume automatically before the navi voice gives directions (other than cranking up the voice volume)? this is for 09 model.
Old Aug 1, 2009 | 02:22 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
It should do it by itself. You can conntrol the nav volume only when its actually speaking
Old Aug 2, 2009 | 12:56 AM
fw09e350's Avatar
2009 e350 4matic
i wanted to do the same thing with my 09... nav voice was barely audible when i first got the car. but the previous post is correct. i jacked up the volume to nav so that it can be heard over the music which seems to lower a tad tho still very audible when nav needs to speak. but im still very new - 2 wks so if i find some other way, ill report back.
Old Aug 2, 2009 | 12:50 PM
pinebaron's Avatar
07 E320 Bluetec
and you may use the RPT key to repeat NAV instruction and may raise or lower NAV volume at the same time.
Old Aug 3, 2009 | 10:25 AM
MB211's Avatar
2005 E500, 2011 ML350
MY09 does not have the option to mute or lower radio volume when nav speaks.....Nav voice just talks over the music.....
Old Aug 3, 2009 | 03:46 PM
Ronaldk's Avatar
W211 E200 Kompressor
Adjustment possible with new software
The above is true for the original software version. However, after software upgrade an additional menu is available to ensure the music is played at a reduced volume when navigation is providing directions.
Old Aug 3, 2009 | 05:18 PM
DrDrilZ's Avatar
GT3, GTR, 570S
are software upgrades free? i just purchased a car but it was probably one of the earlier builds for MY09
Old Aug 4, 2009 | 09:36 AM
Barry45RPM's Avatar
2015 ML 350
Tell the Svc Dept you have a hard time hearing the NAV, & the software update is available.... they'll install it for you free.
Old Aug 4, 2009 | 11:56 AM
Ronaldk's Avatar
Menu layout for Audio Fadeout
Attached is a picture of the Command NGT2,5 (2009) Audio fadeout Menu addition after the software update. (Menu available under "Navi")
Attached Thumbnails option to lower music volume automatically when navi voice gives directions?-command-menu-audio-fadeout.jpg
Old Aug 4, 2009 | 12:05 PM
Franman's Avatar
2009 GL550
is this same software update available for the GL '09 Navi? Mine looks similar to that
Old Aug 4, 2009 | 03:55 PM
konigstiger's Avatar
'71 Pinto
DTB not issued yet confirming update specifics but you can mention Telematics disc #1718273959 for MY09 230/219/211/171/164 and 251 models.
Old Aug 9, 2009 | 02:07 AM
DrDrilZ's Avatar
GT3, GTR, 570S
went to dealer today and they said no updates available yet. didnt have time to argue. what is DTB?
Old Aug 16, 2009 | 11:20 PM
fw09e350's Avatar
2009 e350 4matic
same with me... was told by the selling dealer that they know of no software updates. the person who mentions this update is in So Africa.... has anyone in the US gotten this update? if so please post info so we can get same. thanks.
Old Aug 17, 2009 | 01:01 PM
'71 Pinto
Dealer Technical Bulletin released to dealer from MB
Old Aug 17, 2009 | 02:15 PM
fw09e350's Avatar
2009 e350 4matic
so you actually got this update? your car is an 06 cls. according to mbusa, newer E's dont have audio fade feature while older ones do? wtf... how assinine is that???
if you had it done can you provide me with dealer info so i can talk them directly? thank you.
Old Apr 5, 2010 | 01:05 PM
Mackhack's Avatar
Push the Voice button on your COMAND then change the volume up or down as you want it to be and good. Next time she says something it will be that loud.
And in the settings menu of your navigation on your COMAND you can select the grade of how much the music shall be reduced.
So no update is necessary to accomplish what you want to do.
