E-Class (W211) 2003-2009
Guys top up your oil level!!!
Old Oct 19, 2009 | 09:21 PM
007_e350's Avatar
X166 gls450 2017
so I topped it up (was half way between min and max) & now I see 20 mpg city yeeeeeeeeeehu ... I've never seen 20 in the city before, was around 17~18 max
FYI, according to the manual, its 2.1 qrts between Max and Min, so if u're at min there's still 6.x qrts, in other words it'd take 2.x qrts to reach max from min
Also I got Chevron Techrons fuel inj cleaners from costco, a pack of 6 for 15 bucks!! I'll use one every 1200 miles
Old Oct 19, 2009 | 09:30 PM
Benz-O-Rama's Avatar
**HINT**
With the car cold, call up same secret menu that allows you to put it in dyno mode and check oil level. You can see exact oil levels down to a 1/10th of a quart. Much better than using the standard MFD method where it says "Oil Level OK"
Just did this 10 minutes ago in my SL600 and was running 8.9 qts, which is .10 below the 9qts it should be running. I can live with that. There's probably some oil hanging around in the filter.
Old Oct 19, 2009 | 10:09 PM
MBNUT1's Avatar
2010 E350 4Matic
You don't honestly believe that topping your oil level has any bearing on your fuel mileage do you?
Old Oct 19, 2009 | 10:51 PM
sunny_j's Avatar
09 E320 Bluetec
how many qts does my bluetec need?
Old Oct 19, 2009 | 11:00 PM
It'll be in your owner's manual index under "oil"
Old Oct 19, 2009 | 11:09 PM
sunny_j's Avatar
09 E320 Bluetec
thanks
Old Oct 20, 2009 | 12:06 AM
lkchris's Avatar
'10 CL550, '12 GL550
There is zip/zero/nada relationship between oil level and fuel mileage.
This is simply coincidence.
Old Oct 20, 2009 | 02:42 AM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
well .. if you run no oil .. you'll get crappy mileage ... so I wouldn't say there is no correlation.
Old Oct 20, 2009 | 06:00 PM
007_e350's Avatar
X166 gls450 2017
I think it makes more difference in a 4matic since your piston's power stroke is striving hard to spin FOUR wheels (v6 would delivery 1 pwr stroke every 60 degrees out of 360 - and you want that to last till next one comes in..) Anything n everything that can make that power-stroke well 'lubricated' would actually delivery power more effectively (make it last longer dont u think so ??) - ultimately lifting ur foot off a bit on the pedal ... think small..
just got transmission oil change done for $300 ... now the stealer's saying to do transfer case oil change would be another $400
CAN YOU BELIEVE THAT!!!!
Old Oct 20, 2009 | 06:47 PM
MBNUT1's Avatar
2010 E350 4Matic
As long as your oil is above the minimum level the lubrication will be unaffected in measurable terms of the fuel mileage. As LKChris said just a coincidence. Always remember the adage correlation is NOT causality.
Old Oct 21, 2009 | 02:24 AM
007_e350's Avatar
X166 gls450 2017
Mercedes was just stupid to design engine with 8.5 Qtr oil capacity, or did they know some owners would run at Min ?
You'll have 6.4 Qrts vs 8.5 when at Min - you're saying this wont make a difference in engine lubrication ??
Ignorance isn't always a bliss!
Old Oct 21, 2009 | 11:04 AM
walter34payton2's Avatar
2006 e350
Also, 8.5 quart capacity allows for cooler engine oil which is what MB had in mind I think.
Benz-o-rama.....Would you kindly direct me to find instructions to check engine oil level on the computer for a 2006 E350. I have the dipstick, but I would like to get the very accurate reading this can give. Thanks!
Old Oct 21, 2009 | 04:23 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
Motor oil performs serveral other important funtions in addition to lubricating the engine parts. It does not take much oil just to lubricate the engine parts. However, since most car manufacturers do not include oil cooler as part of the engine set up, therefore, the oil has to perform cooling in addtion to the radiator. Another function of the oil is to keep the engine clean. There are a lot of additives in motor oil and they tend to wear out as the oil gets thicker and dirtier. I would not fill the oil level to the maximum in a cold engine. The mid point beween min and max is the ideal level because as the engine gets hot, the oil expands and reaches the max level. Too much oil causes foaming and foam contains air, and air causes metal to metal contact. That's why there is a max level.
I recently had my tranny oil changed on my G35 by a shop. I check the flluid level found it to be a quart too much. Instead of driving to the shop and had it drained, I used my Top Sider and syphon the fluid out, only took me 15 minutes from start to finish. I don't know the correlation between oil level and MPG since I have never read any article on this subject. My 0.02.
Old Oct 21, 2009 | 08:30 PM
Alright,
So in this thread: https://mbworld.org/forums/w211-amg/...ld-i-know.html, post #2, there is a video showing you how to get into a secret subset of menus. One of which allows you to put your car in dyno mode. Instead of choosing dyno mode, hit the left/up button again and you'll see an oil level screen. While on that screen, turn the key to position #2 and it will perform an oil level check. You will see results in X.X format.
Old Oct 21, 2009 | 09:25 PM
LeviDenim's Avatar
2005 E500 4matic, 99 ML 430, 90 E300
My firmware will not let me access dyno mode.
Old Oct 21, 2009 | 09:37 PM
Firmware? We're not talking about the COMAND system here. Watch the video.
Old Oct 21, 2009 | 09:39 PM
LeviDenim's Avatar
My bad.
I just got back in from trying it. I got to the service data screen and the oil level read --:-
The car was still warm, but it was not level, so I will try it on level ground.
Old Oct 21, 2009 | 09:45 PM
My bad.
Yep, that's the screen. When you're there, just click the key to position 2 and it will check your oil level regardless of engine temp or incline. It does take a few seconds to display the results.
Old Oct 22, 2009 | 12:34 AM
LeviDenim's Avatar
Ahh, I did not go to position two on the key. I left it on position one.
Thank you for the clarification.
Old Oct 22, 2009 | 02:53 PM
I should also state the even though it will give you a reading while hot or on an incline, it will not be accurate. Obviously, for most accurate reading, check with car cold on level ground.
Old Oct 22, 2009 | 03:38 PM
Barry45RPM's Avatar
2015 ML 350
The large oil capacity is chosen so that the oil runs cooler and since there is more of it, it takes longer for it to get dirty enough to warrant an oil change... Thus the once a year oil change interval. Its not enough to have an oil who's lubrication properties last the year, it has to not be fully laden with particulate matter from doing its job. Those are the reasons for the large amount of oil. The min reading is the minimum amount of oil that will properly cool clean and lubricate the engine. More oil doesn't get more slippery, or the answer to car manufacturers CAFE mileage problems would simply be to add more oil to gas guzzlers crankcases.
You can not defend the argument that adding oil gives better gas milage. It simply doesn't.
Old Oct 23, 2009 | 04:36 PM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
BE VERY CAREFUL OF CHEAP INJECTORE CLEANERS! I have only put 44K in my 04 E320 4-Matic once at about 40,000 miles. If you use cheap cleaners and you use too much of them they CAN damage injector seals and other things! Not worth it at all.
I had my transmission fluid changed along with the transfer case at about 28,000 miles and it was about $270. I just had the rear differential serviced and it was only about $60.00. I also had the coolant flushed (I gave them distilled water to use) and had supercool added. I did this just now at bout 52K miles because the PH of the antifreeze had just gone over 8.
Fluid changing on the above mentioned parts is only wise. I don’t plan to change the ATF and transfer case fluid until it hits 100K. As for the oil, My car says that it takes 8.5 Quarts and since my car does not have a dipstick I use the service menu of the car. It has never been bellow 8.1 quarts when the engine is off and 5.2 quarts when the engine is running. I have never had to add a drop yet.
Just my 2 cents,
Steve
Old Oct 23, 2009 | 07:53 PM
007_e350's Avatar
X166 gls450 2017
Excellent Advises - Thanks Steve!!
Couple of questions:
- How do we check the PH of the antifreeze ?
- Which Mercedes Dealership did you go to, I can maybe give reference
- My car has a dipstick, would I still be able to see Oil level in the odo sys display ?
Old Oct 23, 2009 | 08:45 PM
MBNUT1's Avatar
2010 E350 4Matic
+1
Old Oct 28, 2009 | 09:10 PM
007_e350's Avatar
X166 gls450 2017
I dont get the oil level screen ?? I get 4 screens in all, UB - Dyno Mode - VIN/#s etc - Service Menu
I did try key position 2 when in service menu but nothing happened.. am I missing a step ?
thanks rama!
PS> Hows the SL compared to 211
