Replacement Wiper Blades
These bad boys are $8 each, fit properly and with only a garden hose test, perform well. No more horrible chatter (at least for now). If they stand up even for a little while, I intend to stock up. At that price they are pretty disposable.
When I bought the Wagon in August 09 the wiper blades made quite a racket.
Had the dealer put new ones on (no charge for labor) $50.00 for the front pair and $18.00 for the rear wiper.
Dead quiet and smooth, worth every shekel..
I changed to Valeo. It looks like OEM with same fittings. No more chatters. Just a slight noise occationally.
I will try an aftermarket ones next time. Save money, and have better quality? Lets see if it's too good to be true.
These blades were cutting edge in 2003. Now you can find them everywhere and at almost any price so I guess if I have to choose between being annoyed for $50 or being annoyed for $16, I'll take the cheaper price. Those of you (daredevils) that have risked installing them yourselves know that the hardest part is switching the ignition off at the right time to strand the wiper arms in the vertical position. At $16 per pair, I'll probably stock up and change them at the recommended interval ( 6 months from one mfg!!!!) I can understand that UV is probably just as harmful as wear.
I will volunteer to be thankful that such a trivial thread is causing so much response. Transmission contamination is a much more worthwhile concern and thankfully one I can only experience vicariously
In my case, it wasn't just noise. Brand new OEM ones chattered and skipped so bad that it felt like the whole thing was going to fall apart.
Size is 26" (650mm) Comes with the usual bag of adapters and a little pocket coin screwdriver to install the correct end.
It was a tough decision $8 each for these or $25 each for OEM.
These (Anco) expose the end of the attachment pin to the driver and passenger. The OEM do not. I am trying to cope with the shame.
FWIW, I usually buy Michelin wiper blades and remove the rubber insert from them and install it in the MB OEM blade assembly -- I've found that keeping the windshield clean also helps to minimize noise/chatter as well as selecting the top/bottom heat/defrost combo on cold days helps (warms up the windshield).
PIAA makes silicone wiper blades which would be better when it's cold outside but I haven't tried them -- I did try TripleEdge (they're silicone) on my Boxster but they deteriorated quickly (probably due to poor quality).
Regards,
paul...
Regards,
paul...
Sorry, I don't have a part # for the Michelin's -- I usually just go into Walmart and pick up a pair of the 26" (non winter) -- I then take them apart (not in the store, but at home!) and take the MB OEMs apart and put in the new rubbers. I have the process down to a science -- it takes me about 15 mins to replace both wiper inserts. I pry off the MB wiper end cap with a very thin screwdriver, and then carefully lift up the small needle pin that holds the rubber in place, slide out the old one, slide in the new one -- a little silicone spray lube helps.
The PIAA refills are about $10 each (26" for MB is part # 94065).
Regards,
paul...
with the Michelin. I wonder why the Chinese can't get it right?The good ole Mexicans (ANCO) appear to have.
Regards,
paul...
oh and i was wondering if someone could email me the service bulletin for the wiper angle adjustment. please PM me and i'll PM my email address. I have it on my home computer somewhere, but I'm at work right now.
