E-Class (W211) 2003-2009
PIC REQUEST: w211's slammed or lowered :)
Old Jun 4, 2013 | 07:13 PM
  #526
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by pinebaron
Toe in and Caster are within specs following alignment at Cherry Hill MB but needs camber correction (I chose not to use bolts since rears also needs camber adjustment).
Current camber specs (Rears -2.13/-2.19 Front -2.43/-2.3). K-Mac bushings (front and rears) should bring them within specs since they have a +-1.75 adjustment range. The vehicle is going in tomorrow to install the K-Macs (bushings delivery expected today), I could have attempted to replace bushings myself but I let the experts do it on their lift. No doubt it will go back to Cherry Hill MB for another alignment.
After installing K-Mac bushings front and rear the new numbers are now within spec:
Camber: Rears -1.3/-1.5 Front -1.4/-1.4
Toe: Rears .09/.24 Front .11/.10
Total labor 8hrs bushings and 1 hr alignment: Cost $858.09
I'll order 15mm spacers tonight for the front wheels to complete the picture
Old Jun 5, 2013 | 03:13 AM
  #527
AMGAffalterbach's Avatar
2014 BMW M235i
Was the handling adversely affected by having the negative camber when you didn't have the K-Mac bushings installed? If anything I would think it would help cornering... but I don't want to lower my car if I have to spend $900 to just get the camber correct.
Is this needed on AirMatic? Will I be fine besides tire wear if I have the ~2.4 degrees of negative camber all around?
Old Jun 5, 2013 | 06:57 AM
  #528
pinebaron's Avatar
07 E320 Bluetec
Was the handling adversely affected by having the negative camber when you didn't have the K-Mac bushings installed?: Not at all.
The car handled perfectly fine before camber correction. Camber can actually improve handling, especially on cornering. The entire change, awesome Bilstein IRc shocks, lowering to almost maximum limits (considering wider tires I'm using) adding significant camber etc. was a massive change, to my aggressive style of driving. Prior to K-Macs etc change, the car really handled extremely well, like on rails and to quote my daughter who was here last weekend "Papa, your car is like driving on cream" which made my son sneer; he drives a lowered S-Class.
Camber correction was more in my mind than a requirement or need.
It may look a little better (that is debatible), may improve tire wear, then again not really, since I'm using staggered wheels, though I can always swap tires on each axle. I'm not an expert on any of this stuff, it's just scattered knowledge I've gained from the forum and my son (his cars are lowered).
Is this needed on AirMatic? Your airmatic may be different, I have zero experience with it. My son's S-Class has airmatic and he lowered it using a module or something. Look around the forum and see how others have done it on airmatics.
Please don't follow my example if you are thinking about keeping costs down, I'm a little crazy about getting things right, nothing is perfect to me, have a bad attitude to everything, will spend(actually waste) any amount of time and money to improve stuff. Camber correction cost me over $2K including initial alignment at CHMB, K-Macs installation and realignment by the installing shop (Mill Street Tires, Moorestown NJ). I may take it back to CHMB to get an opinion on another re-alignment.
Will I be fine besides tire wear if I have the ~2.4 degrees of negative camber all around?: Probably! Please seek opinion of experts and knowledgeable resources on the forum and elsewhere.
Old Jun 5, 2013 | 11:31 AM
  #529
Craftysince86's Avatar
W211
lowering the car on bags (airmatic) or coils is still going to cause the geometry of the suspension to tweek, the method you do it in doesn't matter. so your camber and toe will change the same when lowering regardless.
negative camber will affect handling, i don't think anyone here will be able to notice daily driving but your tire makes less contact with the ground the more negative you go.
lastly does camber cause premature tire wear? well, that has been the biggest debate for a long time.. a lot of people say that if just your toe is aligned then you will be ok, running a low negative camber number like 2 degrees you'll be fine i think. my 211 is running about 4-4.5 degrees negative and my daily driver is almost at negative 5.5-6 degrees.
Old Jun 5, 2013 | 07:59 PM
  #530
2014 BMW M235i
Wow thank you both for the wealth of information on the suspension geometry. Good replies. It makes sense that a degree more of negative camber would improve handling or affect it somehow but I doubt it would cause too many adverse issues regardless. When I lower via STAR I'll just have MB of Westminster correct the suspension alignment as much as possible even if it is a little bit out of spec. Thanks!
Old Jun 6, 2013 | 06:43 AM
  #531
pinebaron's Avatar
07 E320 Bluetec
I'm planning to have rear fenders rolled though it appears they are already rolled to an extent but there's room for more and I may gain a wee bit more space for further rear camber correction. With the car lowered, rear camber is (now) set to a feasible number to minimize danger of rubbing (when running shocks in Comfort mode) but risk of rubbing has not been eliminated unless I permamently run in Sport mode. I'm not prepared to give up wide 275 tires; 265 would be ideal or better, if my goal was only lowering but I want best of both worlds
Old Jun 6, 2013 | 09:18 AM
  #532
K-Mac Suspensio's Avatar
many
We at K-Mac believe you have done the right thing. We make a very wide range of camber and caster adjusters for most makes of cars because we sincerely believe we can save more than the cost of our kits with improved tyre life over a couple of years.
Yes, AirMatic cars can benefit in just the same way.
Please don't follow my example if you are thinking about keeping costs down, I'm a little crazy about getting things right, nothing is perfect to me, have a bad attitude to everything, will spend(actually waste) any amount of time and money to improve stuff.....
Getting things right is what we always seek to achieve at K-Mac too. Thank you for using our products!
Old Jun 13, 2013 | 03:26 PM
  #533
PHDZINE's Avatar
2007 e550
PIC REQUEST: w211's slammed or lowered :)-benz2.jpg
PIC REQUEST: w211's slammed or lowered :)-benzfalkentire.jpg
Old Jun 13, 2013 | 11:42 PM
  #534
09W211's Avatar
2009 W211 E350 AMG Sport PKG
how much did you widen out the rears by? I was actually looking to widen my rears by 1 inch and was looking for widened rears that didn't go into the doors..good to have for reference. sick 211 too
Originally Posted by PHDZINE
Old Jun 14, 2013 | 02:25 AM
  #535
2014 BMW M235i
Need to kick my W211 game up...
Old Jun 14, 2013 | 04:40 AM
  #536
Sunny1's Avatar
w219 cls
^ insane
Old Jun 14, 2013 | 06:16 AM
  #537
Rotemsmith's Avatar
Maruti 800
Wow man that is quite an awesome E..i really liked the alloys..and the combination is perfect..elegant on the upper side and muscle at the bottom.
Old Jun 14, 2013 | 01:05 PM
  #538
PHDZINE's Avatar
2007 e550
Thanks guys! I actually have the rears flared about 1.5". I have 20x12 in the rear.
Here's a rear shot with the 20x12:
PIC REQUEST: w211's slammed or lowered :)-407421_161171990659802_157269554383379_223925_836449930_n.jpg
Heres a rear shot with 20x11.5" in the rear
PIC REQUEST: w211's slammed or lowered :)-dscn4043.jpg
Old Jun 14, 2013 | 01:51 PM
  #539
09W211's Avatar
do you have any shots looking straight down one side of the car from the back/front? i want to see how the flare/widebody looks from looking straight down one side
Old Jun 15, 2013 | 12:36 AM
  #540
2014 BMW M235i
Awesome looking car overall PHDZine looks really clean. Maybe it's just the angle but the rear profile is just too much for me though. It's only a 382-hp V8 and while I don't mind the stanced look it seems wayyyy to wide for me with 12s. Not to mention the extra weight. Beefy look, but the 12 inch wide wheels overdo it IMO. Don't mean any disrespect and I like your build but just my personal opinion.
Old Jun 15, 2013 | 02:48 AM
  #541
FromM3toE55's Avatar
2003 E55 AMG
Originally Posted by 09W211
money shot!
Old Jun 15, 2013 | 05:05 AM
  #542
09W211's Avatar
Originally Posted by FromM3toE55
money shot!
let's swap wheels! getting all new hardware put on my wheels right now
Old Jun 16, 2013 | 12:27 AM
  #543
W211
damn that thing is yanked! any better shots down the body line from the rear? what did you do for the rear bumper? looks real nice!
Old Jun 16, 2013 | 01:33 PM
  #544
07CivicMD's Avatar
98 C43 AMG
Here are some updated pics with 20" and adjustments to lowering links.
PIC REQUEST: w211's slammed or lowered :)-dsc_0788.jpg
PIC REQUEST: w211's slammed or lowered :)-dsc_0780-1.jpg
PIC REQUEST: w211's slammed or lowered :)-dsc_0777-1.jpg
PIC REQUEST: w211's slammed or lowered :)-dsc_0773.jpg
PIC REQUEST: w211's slammed or lowered :)-dsc_0767.jpg
PIC REQUEST: w211's slammed or lowered :)-dsc_0766.jpg
PIC REQUEST: w211's slammed or lowered :)-dsc_0757.jpg
Old Jun 16, 2013 | 02:32 PM
  #545
2003 E55 AMG
thanks but ill pass bro
Old Jun 20, 2013 | 01:33 PM
  #546
PepperE500's Avatar
2003 W211 E500
Old Jun 22, 2013 | 04:11 PM
  #547
ulovemybenzo's Avatar
99 W210 E55
teaser shot!
PIC REQUEST: w211's slammed or lowered :)-img_20130622_003954_zpsce9cdad0.jpg
Old Jun 24, 2013 | 06:21 AM
  #548
pinebaron's Avatar
07 E320 Bluetec
Who flared the rears for you and what was involved?
Old Jun 25, 2013 | 02:26 AM
  #549
2003 E55 AMG
Originally Posted by PepperE500
nice! 19"?
Old Jun 25, 2013 | 03:34 AM
  #550
2014 BMW M235i
^ I can't tell is the car blue or such a shiny black it reflects everything
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
