E-Class (W211) 2003-2009
Suspension is low
Old Jan 10, 2010 | 07:08 AM
ssj555's Avatar
W211 2006 E220 CDI
Exclamation Suspension is low
Hi
i was driving my car today and the car was wobbling. When i parked up i noticed that the driver side arch was almost touching the wheel,
I rang mobilo roadside recovery and they recovered my car and it is due in for the dealers to check under warranty.
Does anyone know why this could have happened? It was fine before, car is standard and does not have airmatic!
Will this all be covered under exteneded warranty?
Surjit
Old Jan 10, 2010 | 07:28 AM
herrakani's Avatar
e220CDI
Like this? Mine's got a frozen air valve due the winter.
Old Jan 10, 2010 | 07:50 AM
ssj555's Avatar
W211 2006 E220 CDI
yes it looks like that, do you have airmatic i just have standard sport suspension, how do you go about fixing it because i am taking it to the dealer tommorow so if its fixable at home let me know although i think its covered under warranty.
Old Jan 10, 2010 | 08:01 AM
herrakani's Avatar
e220CDI
Mine works when it's over -5 degrees fahrenheit so I'll just mention it when going to the next regular service. I got airsprings only on the rears, I don't have the airmatic buttons in the center console.
Old Jan 10, 2010 | 08:11 AM
ssj555's Avatar
W211 2006 E220 CDI
well its been like that overnight and no change. Also i have all four springs so i dont think it may be that problem. I will have it diagnosed at the dealers at see what they say
Old Jan 10, 2010 | 09:45 AM
Diesel Benz's Avatar
Do you have a sedan model? Was it the front or the rear of the driver side that was low?
Old Jan 10, 2010 | 12:42 PM
ssj555's Avatar
W211 2006 E220 CDI
front driver side
http://www.benzworld.org/forums/w211...ml#post3920167
pictures on there
Old Jan 10, 2010 | 07:21 PM
M.leonard2's Avatar
2004 E320 4matic, 12' 300, 95' Deville(RIP)
Um im not a Mechanic But um
you have airmatic. you said you have the sport suspension in your pics on Benzworld i notice you have the sport wheels. so that means you have the sport package. You shock is blown so maybe take up the $400shock offer from kiamcoj on benzworld just my imput
Old Jan 11, 2010 | 02:07 AM
And how did you conclude the car has Airmatic? Why would a blown shock make the car bottom like that?
Old Jan 11, 2010 | 08:38 AM
ssj555's Avatar
W211 2006 E220 CDI
Im from the uk, the car is avantgarde, Which i think is the sports in the US, it doesnt have airmatic just the sports springs. its gone into warranty today so i will not need to buy new springs, I will update when i recieve the car back.
Surjit
Old Jan 14, 2010 | 05:18 AM
herrakani's Avatar
e220CDI
Mine works again normally.
Old Jan 14, 2010 | 09:34 AM
ssj555's Avatar
W211 2006 E220 CDI
its all sorted now. The spring was broken and they replaced both for free under warranty.
Old Jan 15, 2010 | 09:02 AM
vettdvr's Avatar
03 E500 and Corvette
I assume you mean Air Spring. If this is the case note the mileage and expect another failure about the same miles.
Mine has also failed been replaced. I spoke to the service mgr and he said this is a common problem.
Old Jan 15, 2010 | 10:55 AM
No, no, this was specifically arranged for vettdvr, a steel spring got broken. You should consider the new 212 with something else than steel or Airmatic springs.
