help! car wouldent start!
i was out to get some food and made a few stops and the car was fine then i park it to pick up our food and when i go to leave the car just turns over but it wouldent fire up.
after geting pissed i pulled the fuel pump fuse and put it back in then it hesitated to start for a sec but it fired up and after i drove it about a half of mile home i turned the car off then tryed starting it and it cranked up normal.
now i have a check engine light on.
is there a dionostic port on this car? i have a buddy that can scan it for me.
what could of caused this?
now im scared to drive it any where
.please help guys!
~shaun
all in all i started it about 10 time in a few hour period and it was perfect every time.
.please help guys!
~shaun
beats the 132 from the dealer!
i got a pdf of the swap and it seems to be on the rear drivers side and its just 1 bolt.
it is a cheap part so its not that big of a deal it it fail it more agravation than any thing geting stuck.
44 online is also with out shiping and i would have had to wait over the week end and the car was down for almost a month because of a door latch the wouldent keep the door shut so.
Wouldn't hurt to clean out or replace the MAF sensors too while you're at it.
To confirm, it is CRANKshaft and not CAMshaft position sensor?
Reason I ask is that our old BMW E36 had both, and I don't know enough about our W211 to know if it has both also...
Engine also seems to be idling low or a little rough sometimes. Would that be related or not?
Any advice? Is there a tool someone can recommend?
just about all cars have both, but yes this refers to the CRANK position sensor.
That sensor is not the Crankshaft sensor, that is the Camshaft sensor
JR
