E-Class (W211) 2003-2009
Got E63 Brakes :)
Old Jan 21, 2010 | 04:09 PM
155's Avatar
155
R350
Got E63 Brakes :)
Hi all,
Big thanks to Daminchi for the perfect set of E63 brakes and Konigstiger for the technical assistance. Sweet geezus these things grab hard!
If anyone's interested, the brakes are straight bolt-on with the exception of needing E55/63 front spindles. Front sprindles run approximately $550-600 USD for the pair.
A few other notes:
- My old brakes had brake sensors on all four sides, the E63's have two, one front and one rear
- The brake dust shields have to be modified. I used the shield from the E63 for the fronts and i cut my stock rears.
- The lower ball joint on my passenger front was toast so that assembly was replaced at the same time
On to the pictures!
Old Jan 21, 2010 | 04:48 PM
nstanford99's Avatar
Ferrari 488
lookin beautiful my friend
Old Jan 21, 2010 | 05:14 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
They're super great binders but get ready for major dust and squeal. Unfortunately there's no aftermarket dustless pads available yet for the E63.
Also big cost for pad/rotor replacement, but you already know that.
All that's left for your car now is to drop the 6.2 motor in there
Edit: just curious, did you pull the whole SBC ecu out of the car? Just wondering about codes etc., if you had SBC and then put in non-SBC brakes.....
Old Jan 21, 2010 | 05:19 PM
M-bENZ's Avatar
Corrolla
now you only need the cf front lip and you're set .
btw, nice rims man.
Andy
Old Jan 21, 2010 | 07:06 PM
Benz-O-Rama's Avatar
Get's a big from me.
Old Jan 22, 2010 | 12:12 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
SSSSIIIIIIICCCCCCCCKKKKKKKKKKKK!!!!!!!!!!!!!!!!!!
u gonna just leave it silver or paint them?
Old Jan 22, 2010 | 08:34 PM
155's Avatar
155
R350
Well, I'll be honest that I didn't realize the later model W211's are non-SBC! I figured that the 55 and 63 brakes were compatiable and I went for it. They work incredibly well and I'm very relieved it worked. SBC is hooked up like the factory intended.
I brought my car to MB to bleed the brakes and check codes. Besides some battery-related low-voltage codes everything was perfect.
Thanks!
Originally Posted by M-bENZ
now you only need the cf front lip and you're set . btw, nice rims man.
I must be only one of a few that prefer the front end without a lip One of my fav wheels of all time are the Kleemann TS-6's but they're $$.
Thanks Clay. Your car was my inspiration
I was looking into painting but the whole project was expensive enough. I was going to do Brembo yellow... we'll see what happens down the road
Old Jan 22, 2010 | 08:52 PM
Question:
How much does it cost to get calipers painted? Now that I've purchased some mack daddy wheels for my SL600, I think I wanna do mine but I have no idea how much that costs.
Old Jan 22, 2010 | 09:04 PM
220S's Avatar
Hmmm. Interesting. So you have SBC still? Did you upgrade to the later version (I think 2004-5) or keep what you had?
What model year E63 did the brakes come from?
I guess Konigstiger would have mentioned something about it working or not. I don't know SBC very well, but I'm guessing now that the SBC ecu will hook up to any conventional system (?) I know that changing pads on SBC systems requires disabling the computer, although some people say you can just shut the doors, lock the car, let it sit for 10 minutes first and then the calipers stay put (the car thinks it's just sitting there and won't brake)
Anyway, they are super brakes. Get ready to wash your wheels every day. Brake dust is pretty intense. I wish Porterfield or another vendor would come out with E63 dustless pads.
Old Jan 25, 2010 | 12:42 PM
155's Avatar
155
R350
Question:
You've got PM
Yes, I kept my original SBC system and it seems to be working perfectly so far. The brakes came from a 2007 E63 which approximately 15k miles. On a side note the front rotors were surprisingly worn considering the mileage...
Which makes me wonder if A) the PO drove like a bat out of hell B) the rotors wear faster than other makes/models or a combination of both.
My mechanic said there's about 60-70% life left in them... thank god I don't drive much as replacement cost for the rotors alone are pretty ridiculous.
I should clarify that Konigstiger helped with part numbers and not the actual brake conversion. Your correct on the brake change procedure with the SBC systems. The only note to add is to roll down your windows!
Old Jan 25, 2010 | 01:21 PM
sunny_j's Avatar
09 E320 Bluetec
You've got PM
that makes sence because he did crash the car lol
Old Jan 26, 2010 | 12:27 PM
dacollector's Avatar
13 E350 , 12 BMW 328i
nice job,
man brings me back memories when i tore apart the front spindles doing the work in my garage for 2 days.... i wonder what is the difference with E55 vs. E63 brakes? was thinking of going with CLS63 fronts...
Old Jan 30, 2010 | 02:16 PM
Frasmat's Avatar
W212 E350 P2 AMG Appearance
Looks Great.
Old Jan 30, 2010 | 06:58 PM
tbone's Avatar
E500 Sport
I see some bright red paint in your future
Old Jan 30, 2010 | 08:08 PM
gaazmon's Avatar
i concur
Old Feb 4, 2010 | 01:09 AM
155's Avatar
155
R350
i concur
LOL you two
Cant a guy enjoy his 6 pot calipers in peace?
Old Feb 4, 2010 | 10:50 AM
tbone's Avatar
E500 Sport
LOL you two
NO
