E-Class (W211) 2003-2009
How hard and expensive is it to retrofit Parktronic?
Old Mar 2, 2010 | 03:02 PM
Mackhack's Avatar
Is it hard to retrofit Parktronic in our car? I assume all I have to do is placing the control unit into to bracket in the trunk, replacing the impact strips with the sensors on the bumpers and connect everything with the system?
Old Mar 2, 2010 | 05:02 PM
CLK Masters's Avatar
04 CLK 500, 07 GSX-R 750, S 550, 09 Jeep GC
tear open rear shelf and front dash to install the readout units. in my opinion not worth it. Especially with a smaller car. (no Offense) if you had a CL or a S..... somehting more than 200 inches than it might be worth it.
Personally just take 20 min learn exactlly where your ends and you'll be good. when i Drive my Mothers S550. I turn the damn thing off, gets annoying to me.
Old Mar 2, 2010 | 05:06 PM
Mackhack's Avatar
It's not about me. I learned everything from parking front in, reverse, side you name it to driving on the Autobahn with 250 km/h in Germany in driving school as it is mandatory to get your license. It's more about GF and the hobby of retrofitting my car.
Old Mar 2, 2010 | 07:58 PM
Barry45RPM's Avatar
2015 ML 350
Has been done by Steve..... BIIIIIG Job. MUCH cheaper from the Factory.
Old Mar 2, 2010 | 08:18 PM
Mackhack's Avatar
Darn...
Old Mar 3, 2010 | 01:18 AM
I hear ya, on the hobby. That's why i did all the work on my car.
But like the other guy said, LOTS of work.
Old Mar 3, 2010 | 01:44 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Darn...
You know someone is dedicated if the retrofit the Xenons, auto-level, AND washers!
Old Mar 3, 2010 | 04:09 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
but you guys know what, it's a mod that can end up paying for itself (avoiding dings and paint damage).
Old Mar 3, 2010 | 08:12 AM
vettdvr's Avatar
03 E500 and Corvette
Why not just add a rear cam. Ok it is aftermarket and not "MB" but will give rear view. I saw one in AZ last week at the check out on display.
Old Mar 3, 2010 | 11:12 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Added Parktronic to my 210 (REAR ONLY) and it required a wire harness,control unit,new rear dome light assy for display,rear impact iith sensors and a LOT of labor ...For rear only its called park stop option in europe
Old Mar 3, 2010 | 11:40 AM
Diesel Benz's Avatar
I've never heard of a "rear only parktronic" in Europe, but in Canada they call it Quick Park.
Old Mar 3, 2010 | 11:44 AM
In my opinion the rear view camera is not as good as Parktronic. Not only because it does not watch after the front but also because drivers are used to watching backwards or the rear view mirror which is not possible while watching the camera.
Of course a camera is a lot better than nothing but if I had to choose one or the other, I would definitely go for Parktronic.
Old Mar 3, 2010 | 12:19 PM
Mackhack's Avatar
Hey Mark,
thanks for the (partial) list of things I would need. One thing though. Never count the time if its your hobby. Lot's of mods on our cars need a lot of labor, if you don't have to pay someone this is free in any way.
Old Mar 3, 2010 | 01:35 PM
gaazmon's Avatar
i am not a big fan of the rear view camera thing. all i would need is the audible indication actually. i don't really need the visual indication with the LED strip, but it helps.
Old Mar 3, 2010 | 01:40 PM
Mackhack's Avatar
Correct, the MB Sprinter for instance only uses audible indication and we used to have one back home. The faster the beep the closer to an object, solid beep only 5 cm = 2 inches away from the object.
@gaazmon, did you hardwire your Cobra?
Old Mar 3, 2010 | 03:45 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
We bought our S211 used and it has aftermarket parking sensors in the rear of the vehicle only, with a control unit mounted in the rear quarter panel and "audible sensing" only, no light meter or anything up front.
Those things are likely a dime a dozen on the web, and frankly will get you 99% of what you need.
Old Mar 3, 2010 | 06:29 PM
gaazmon's Avatar
no i've never looked into it actually. i take it out of the car and move it around a lot so never really thought about it. how difficult is it? i guess i can still move it around and use cigarette lighter plug for other cars but keep hardwiring in my E320.
Old Mar 3, 2010 | 06:35 PM
Mackhack's Avatar
I'll try to find stable 12V in the front dome light. I also found a cable for 25 bucks that supposedly works that way. But I looked closer to that cable and there is nothing on it that a simple cable out of my electronic box can't do. So I rather save the 25 bucks and make my own cable with a RJ11 connector. Once it works, I'll post on this forum.
Old Nov 27, 2010 | 04:19 AM
WEBSRFR's Avatar
Tesla Model S P100D
Any news on this did you manage to retrofit Parktronic?
Old Nov 27, 2010 | 02:53 PM
Mackhack's Avatar
I have the wiring diagram if you mean that?
Old Dec 26, 2010 | 10:02 AM
dewana421's Avatar
E320 2004 model Silver sedan
Mackhack can you post the wiring diagram?
did you end up doing that mod to your car? I just bought an AMG rear bumper for my car but my car does not have parktronics and this bumper has parking sensors holes in it. i am confised about what to do?
Old Dec 26, 2010 | 02:20 PM
WEBSRFR's Avatar
Tesla Model S P100D
Too bad there is no inexpensive solution for adding Parktronic. I am still having a hard time figuring out where the right front corner of the car is and I ALWAYS err on the side of caution and sometimes feel silly in tiny DC parking parking lots as I take 0% chance of scrapping anything.
Maybe an inexpensive parking aid retrofit would be adding retractable three pointed star MB dongle thingies to all 4 corners and the back of the car. I am joking of course... Still might not be as silly as me doing a 10-point turn in a confined space.
Old Dec 26, 2010 | 02:40 PM
Mackhack's Avatar
I can check. I didn't do it and I won't do the mod. I can park in and don't need the aid and don't wanna spend the money on that mod anymore. I just thought it would be cool to have.
Old Jun 19, 2012 | 06:42 AM
dunnman99's Avatar
2003 Merc E-500
Backup / parking sensors
Hello,
I am going to install and aftermarket parking sensor kit, and it is turned on but the 12V that is applied to the back up lamps.
Anyone have a wiring diagram or breakout for the tail light harness?
Thank you,
Old Feb 22, 2020 | 08:53 AM
ILLMATIC96SS's Avatar
Fxt E55 E63
E55 parktronic
Anyone have a contact # for Steve MBENZNL. ?
