Ceramic Brakes...which ones are good?
Many if not all of the current ceramic pads, are great. Mercedes pads/rotors never really lasted much more than one set of rotors anyway.
However I just put a second set of ceramic pads on my SIL's E320 and they did not need the rotors replace! Anyone looking for a set of used front rotors and new rear rotors (both cross drilled) and local should buy the extra set I have. This car had 'Posi Quiets' (cheap) without any problems.
I'm about to put new pads on my E500 and thinking of Akebono again.
With stock pads you would be lucky to make it 10 stops without noticing the brake dust, with ceramics you can go literally days!
Any advantages to aftermarket pads?
• More grab?
Debatable, but yes, and I like it like that and after a couple days most people don’t notice the additional braking.
• Less dust?
Definitely and this was the number one reason for me changing.
• More noise?
Nope never, but I heard that some people who puzzyfoot around in the cars too much tend to hear some noise, this is true with the factory pads to a lesser extent too. You just have to get the brakes hot once and you don't have to worry about it for a couple thousand miles again.
The The PosiQuiets are a little cheaper than I would normally go, I don't normally recomend such a cheap ceramic, but they have proven to work well for this E320.
