E-Class (W211) 2003-2009
lower ball joints CDI with 100k
Old Apr 29, 2010 | 04:00 PM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
Took my 05 CDI in to dealer for end of warranty (100k) once over and specifically asked that they check the suspension. All check out just fine they said.
A week or two later I took it in to an independent shop for an oil change. They told me the lower ball joints are worn. Shop mechanics are all ASE certified, it's a good shop.
Called my dealer and the will re-examine next week.
Does anyone have any thoughts or comments on this?
Old Apr 29, 2010 | 09:15 PM
WRC7732's Avatar
2005 E320 CDI
Not surprising. They're pretty notorious for wearing out. As for the Stealer not telling you, disappointing but not at all surprising......
Old Apr 29, 2010 | 09:36 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Don't be surprised either of any mechanic telling you something is bad when it isn't.
Old Apr 30, 2010 | 08:16 AM
SEC1939's Avatar
agree with both points. eitherway hopeing to get new ball joints. Dealer has nothing to loose really in fact they make money on such a deal.
Key to me on this stuff is if they really do the work not just collect the $$ hours and spare parts for the shelf. I think I'll put a mark on the old ones today
Old Apr 30, 2010 | 08:51 AM
vettdvr's Avatar
03 E500 and Corvette
Welcome to my world. My ball joints failed about 70,000 miles. They were squeeking so loud you could hear the car before it arrived.
Old Apr 30, 2010 | 09:45 AM
SEC1939's Avatar
ball joints
No noticable noise or vibration or clunking. did the warranty cover ? what was the $$ either way ?
Old Apr 30, 2010 | 10:00 AM
vettdvr's Avatar
My extended warranty covered premature failure.
At 100000 they might call it "normal" wear. Expect around $650+ at the dealer. Also verify they did alignment. They only changed joints on mine but no alignment and the !@#$# car would not drive straight.
Old Apr 30, 2010 | 02:10 PM
WRC7732's Avatar
2005 E320 CDI
I'm not sure how they are determining that they are bad with no noticible noises coming fom the front of the car.
When mine was bad there was a very noticeable clunk in certain circumstances and it got bad enough that I couldn't stand it. The only way I would think you could tell would be if the wheel assembly could be shaken by hand (I would think you'd have a clunk aby this point) or the rubber boot was damaged (I haven't seen this on a ball joint).
As far as the $'s go, I bought mine on e-bay for $69 each. Much better thatn the $200+ each that they want at the dealer just for the parts. As for the labor, if you are reasonably handy with car work you could do it yourself. I did mine in about an hour on a lift.
Old Apr 30, 2010 | 03:06 PM
vettdvr's Avatar
Did you install them yourself?
Old Apr 30, 2010 | 04:11 PM
Taylor-Made'90's Avatar
'24 GLE53 AMG Coupe
Bought my ***** on eBay and had my Benz mechanic press 'em in at the Stealer.....
Old Apr 30, 2010 | 06:24 PM
WRC7732's Avatar
2005 E320 CDI
Yes. Installed myself. Though I must say I'm a little more handy than the average DIY'er. I have my own lift and a decent set of tools. Including those stupid 12 point serated edge bits that MB and VW love to use.
Not sure I'd recommened that just anyone try this, especially if all you have is your jack out of the trunk of the car. Just wanted to say how long it took to give an idea of how many labor hours they should be looking at when having this job done.
Old May 2, 2010 | 06:46 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Ball Joints
Also, check the rubber boots of ball joints of torque strut for cracks, if any they should replace the whole strut. They just did this to my car last week. No need of alignment to be performed except if they do any work on the tire road ends.
