Steering Tilt Motor Problem - 2004 E500
Does this plug directly in or off to the side like the cigarette lighter?
Edit Answer: Do not pull the connector there is a lock that moves back and forth on this connector just like the headlight switch.
Its out!
You probably have to use "Some" degree of common sense about use of these motors. The convenience system does put a burden on some of the motors. As a matter of fact I am thinking about undoing my Backup Assist convenience where the passenger-side mirror gets tilted every time I put in reverse gear.In a normal usage of any car's mirror adjustments how often you think s/o would adjust their side mirrors? May be at the rate of once per month (just to come up w/ an "average" number). Now think, every single time you park the car, when getting it out of the parking slot (whether garage, driveway, shopping, ...) you put in reverse. How many time per day is that, and calculate to the month.
Now that number vs. the average of 1 time per month, yeah definitely is excessive wear on the motor. Unless it is something (really) necessary otherwise I would not want to use something that excessively -- unless I pay up for the replacement and work and not then complain about it.
If you read my comment, this is what I said "Unless it is something (really) necessary otherwise I would not want to use something that excessively -- unless I pay up for the replacement and work and not then complain about it."
So it has to be "really necessary", and
one should be willing to pay up for teh replacement parts and the related labor, as well as then not complaining about spending the money. In such a case, fine
Or are we just complaining about how difficult it is and if we should use tilt or not.
How about some help for doing the work?
