E-Class (W211) 2003-2009
Nagivation Question
Old Sep 26, 2010 | 09:36 PM
flossinlo05's Avatar
w211
Nagivation Question
Hi All -
I tried searching for an answer but wasn't sure what to search under....
When I am following the directions via NAV....As the NAV tells me a turn is coming up, the screen spilts. The left side is a close up of the map and the right side is the actual turn in so many feet and direction. Well, the the left side of the screen is no longer a close up of the map but a bird's eye view of the US map. Is there a setting that I need to adjust to get the close up map back?
Thanks in advance...
Old Sep 27, 2010 | 10:44 AM
starbrite's Avatar
2004 E320
If bird's eye view, then I assume it's an '09?
The answer is probably right there in the owner's manual. Did you look ?
Old Sep 27, 2010 | 12:19 PM
w211
I have an '07. The NAV dvd was replaced with an '09 by dealership because my '07 disc wasn't reading. Otherwise, I would of looked in the manual frist before posting.
Any help is welcomed...
Old Sep 27, 2010 | 01:24 PM
starbrite's Avatar
2004 E320
Ok, unless I'm missing something, the "birds eye" view wasn't on w211's until '09 (hard drive based nav, no dvd)
Old Sep 27, 2010 | 01:42 PM
w211
Well....it was different. The bird's eye view on the '07 disc was a close up of the rooute being taken. With the '09 disc, the map zooms out and shows the US and Canada with a star/flag denoting my location in TX. Obviously, a zoom out view of the US map does me no good as I'm following the driections of the NAV system.
Any suggestions?
Old Sep 27, 2010 | 02:30 PM
Barry45RPM's Avatar
2015 ML 350
Any suggestions?
I now have an 09 disk in an 07... Works like it always did. However in one of the soft keys there are split screen settings you can make.
Birds eye view refers to a view similar to flying like a bird with closer objects on the map larger than farther away objects, with the perspective in the distance converging towards the center. (Artists call it the Vanishing point) There would also be sort of a view of the sky far away, above the horizon liine. Some birds eye views also show the curve of the earth's surface where the sky meets the ground.
Old Sep 27, 2010 | 03:25 PM
starbrite's Avatar
2004 E320
Any suggestions?
OK, your terminilogy completely threw me off.
What you're describing is NOT birds eye view, it's just zoom. Barry's answer is correct.
Old Sep 27, 2010 | 06:30 PM
w211
Ahhhh....soft keys. Got it! THX!
Old Oct 1, 2010 | 10:26 AM
Long Islander's Avatar
2018 E400 4matic Wagon
Barry, with your new disc, is it possible for the map to always show the 3D bird's eye view?
Old Oct 1, 2010 | 10:48 AM
starbrite's Avatar
2004 E320
Oggie, it NEVER can because it doesn't have the capability.
Barry was just describing what bird's eye view is because the op mis used the term. (he meant "zoom out")
Hard drive based nav in '09 was the first w211 w/the capability.
Old Oct 1, 2010 | 01:44 PM
lsbrodsky's Avatar
2016 Jaguar FT-R
Birds-eye is not all that great. I tried it in my 09 but I want the NAV to always be North UP(my nautical training) and you cannot do that with birds-eye. It stays Heading UP.
Larry
