E-Class (W211) 2003-2009
2009 E350 FSS reset
Old Oct 20, 2010 | 04:07 PM
BobbyT's Avatar
2023 E450W, 2020 GLC300
2009 E350 FSS reset
My E350 has only 16,000 miles on it, and is running perfectly, but the FSS message came on for Service C. The OBD will alert me of any engine faults, and I regularly inspect belts and hoses. It has been one year and 7,000 miles since Service A, so I don't see any reason to pay the dealer to check the car for stored codes or faults, at least at this point.
I had the dealer do an oil and filter change, which including checking and topping off all fluid levels + tire pressures. Very fairly, they stated up front that they don't reset the FSS.
I don't find any instructions in my manuals for resetting the FSS, except that "shops other than M-B will find the instructions in the materials for this car", or some such.
I tried the following procedure several times, but no joy:
  1. Turn ignition key to position 2
  2. Press reset button twice within 4 seconds
  3. Turn ignition back to pos 1
  4. Press and hold the reset button
  5. Turn ignition to pos 2
  6. Keep pressing in the reset button (the button to the left of the odometer) until a buzzer sounds and a new miles display appears
Anyone have the correct procedure for this model?
Old Oct 20, 2010 | 04:27 PM
ohlord's Avatar
Call up the service
section on the menu from your steering wheel controls.
Procedure in the owners manual then try
http://www.mercedestechstore.com/pdf...2008-16-02.pdf
to confirm.
or you can get a one day subscription at
http://www.startekinfo.com/StarTek/
and follow the procedure
16000miles and they require a 3 hour service?the benz is hardly broken in
Old Oct 20, 2010 | 04:38 PM
ohlord's Avatar
W211
back door link might or might not apply to your 09 w211
http://www.startekinfo.com/StarTek/o...stedDocId=9516
http://www.startekinfo.com/StarTek/o...tedDocId=10502
Old Oct 20, 2010 | 05:05 PM
BobbyT's Avatar
ohlord--I'm still unable to find correct reset procedure--thanks for the help...
Old Oct 20, 2010 | 05:19 PM
BobbyT's Avatar
Found it! It was on the next page of downloadable PDFs here:
Thanks, ohlord!
Old Oct 20, 2010 | 05:35 PM
ohlord's Avatar
If you dig
around those pages you can pull up the services check sheet
do them all and record them in your service book as performed an MB can't negate your warranty if you performed the work required.
Old Oct 20, 2010 | 05:43 PM
06e320cdi's Avatar
2008 ML320CDI
Are you kidding me? Whats their excuse for not resetting at least stating the service 12 (oil change was done). Thats just pure arrogance on their part.
