E-Class (W211) 2003-2009
2005 E320 fuel odor
Old Jan 29, 2011 | 11:15 AM
SDBob's Avatar
E320
2005 E320 fuel odor
Suddenly after refueling my 2005 E320 the other day, I noticed a strong fuel odor coming from the driver's side of the vehicle. After dismissing it as nothing since I had just refueled, I noticed it a couple days later. Seems to be coming from the driver's side rear wheel well. Car runs fine and no evidence of fuel leaking anywhere.
What is the cause and is this something that can be repaired for a reasonable cost? (under a couple hundred dollars)
Old Jan 29, 2011 | 02:29 PM
konigstiger's Avatar
'71 Pinto
Remove lower seat cushion and check fuel filter for leaks (i.e.: hose connection, seal, etc.) if there is no indication of leakage, worst-case scenario tank may need to be replaced.
Well discussed matter, set Display Options (lower left of page) to beginning to search forum.
Old Jan 29, 2011 | 07:06 PM
SDBob's Avatar
E320
Thanks for the tip Konigstiger
Did as instructed and found fuel pooled in the component (pic attached). So now what?
At least you didn't say worst case scenario, the car blows up in the driveway
Old Jan 30, 2011 | 12:30 PM
desired_speeds's Avatar
2007 SL55 AMG
dealer recall!
Old Jan 30, 2011 | 01:36 PM
SDBob's Avatar
E320
There's a recall?
I haven't seen that posted in the forums before. Any detailed info?
Old Jan 30, 2011 | 03:43 PM
'71 Pinto
Not a Recall but rather Service Campaign 2008020001 that applies to MY03-06 211 (E) & 219 (CLS) AMG models only.
http://www.benzworld.org/forums/w211...gas-smell.html
Old Feb 10, 2011 | 04:03 PM
mshrout's Avatar
2005 E320
I'd like to give my 2 cents, I also own a 1999 Volvo S80 T6, please no snicks or sarcasm, I know I know... but I recently replaced the fuel pump on this dude and I think what has failed is the rubber o ring under the lock. After replacing the fuel pump I had alot of fun trying to get the new rubber o ring to seal. mechanic told me to use dawn diswashing liquid on o ring instead of vasoline. not a lot, but wipe it on the o ring, then place the lock ring back down and tighten the best you can, do not over tighten, once I did this, no more fuel leaks or vapors. Also, after doing this, try only filling tank to half full, and then fill up all the way.. with next fill up and see. could not hurt.
Old Dec 27, 2014 | 07:14 PM
globalfx's Avatar
E320
Warranty extended through 2020 re gas smell/ fuel pump E320
Warranty has been extended through 2020 to repair gas smell/leak issue.
http://www-odi.nhtsa.dot.gov/acms/cs...3003-61085.pdf
