E-Class (W211) 2003-2009
Can I change 1 tire instead of all 4 on my 2008 E350 AWD?
Old Dec 22, 2014 | 02:40 PM
georges66's Avatar
2008 Mercedes Benz E350
Exclamation Can I change 1 tire instead of all 4 on my 2008 E350 AWD?
Hi,
We have a 2008 E350 AWD 4MATIC Sedan. My wife had a flat tire the other day and by the time she realized and pulled over, the tire was ruined. All four are 1 year old Michelin Primacy MXM4. I took it to the shop where I got the tires and have the tire warranty and they're happy to replace the one tire, but they advised me that I could ruin the AWD if I don't change all 4 tires due to the difference in wear between the new and the old. Is that true? Do I have to change all 4 tires? He said something about the difference in wear is about 3/32.
Thanks for the advice.
Old Dec 22, 2014 | 03:52 PM
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
Short answer... the sack of shot is lying through his teeth trying to get you to spend money.
I run my 4Matic staggered in the summer. As long as you don't go crazy it's not an issue for the 4Matics.... so a little tread difference is not an issue for the differential or anything like that.
If you want to be generous to the jerk, buy one (plus the one he replaces) and put one of the old tires in the trunk as a spare.
Old Dec 22, 2014 | 04:41 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
If the tire looks like new you can buy 1.
If it is noticeably worn you should buy 2
You don't need to buy 4.
Some tire shops have become "pissy" on this point, probably out of an unwarranted fear of being sued.
Worst comes to worst, take the wheels in off the car to get the tires
Old Dec 23, 2014 | 11:03 AM
georges66's Avatar
Thank you all for the helpful replies. You've confirmed my thoughts.
Old Dec 23, 2014 | 11:20 AM
N_Jay's Avatar
One more quick thing.
Depending on how often you replace tires, you might want to think about replacing all 4 just to get and keep the typical 4-tire discount which you will miss out on once you go to replacing in pairs.
So: . . . . .
if less than 1/2 worn buy 2 knowing you will be dumping two not yet worn out on the next 4 tire change.
If more than 1/2 worn consider 4 now.
Old Dec 23, 2014 | 11:24 AM
georges66's Avatar
Sounds very logical. I'm leaning towards replacing 2, and using an old one as a full size spare. Thanks again.
Old Dec 23, 2014 | 11:29 AM
N_Jay's Avatar
Yep, very!
The suggestion came from my very logical brother after "very cheap" me only did 2 tires.
Went back and talked Discount Tire into giving me 2 more with a 4 tire discount.
Old Dec 23, 2014 | 11:42 AM
georges66's Avatar
That's smart. I got my original 4 (245/45R17 95W Primacy MXM4) for $770 balanced and mounted with waranty and repairs, over $1200 cheaper than the dealer wanted. So $197 for just one is not a bad deal if I get a second under warranty. That's like 2 for $197 or a hundred a piece. Any which way you look at it, it's still a good deal.
Old Dec 23, 2014 | 12:21 PM
cetialpha5's Avatar
So: . . . . .
You could always just buy 4 tires and mount just 2 assuming that you have room to store the other 2. Then when the other two wear out, just pay to mount the other two. Only drawback with this is that they say you should get rid of tires after about 6 years so if you drive enough, it shouldn't be an issue. I ended up doing this for another car where they had a buy 3 get one free plus a big rebate on top of that. The math worked out cheaper to buy 4 tires than just 2.
Old Dec 23, 2014 | 12:24 PM
Honcho's Avatar
...or three for $197: The 'paid for' one, the warrantied one, and the 'leftover old one' that goes in the trunk as a spare.
...or three for $1,200: The 'paid for' one, the warrantied one, and the 'leftover old one' that goes in the trunk AND the new WHEEL to put the tire on
Old Dec 27, 2014 | 08:26 PM
georges66's Avatar
Ended up getting two new tires on the back, and making an old one a spare. Thanks for the advice. Appreciated the input.
