E-Class (W211) 2003-2009
Rubbing sound when turning 06 E500 4matic
Old Jan 30, 2011 | 04:54 PM
AndyD's Avatar
99 SLK230/09 C300/06 E500
Just picked up an 06 E500 4matatic with 60k miles. Great ride, but just noticed that there is a rubbing feeling when making a full left or right turn. No vibration/rubbing feeling when driving straight away or making a slight left or right turn. Any help/ideas would be appreciated
Improper tire rotation????
Old Jan 30, 2011 | 09:10 PM
t-bone's Avatar
2004 E55
Did you check to see if the power steering fluid is low? I had a similar issue. Not sure if your sound is the same as mine, but my power steering fluid was low. Adding more solved the issue.
Old Jan 30, 2011 | 09:49 PM
socketman's Avatar
r
change the fluid in the tranfercase, then go out and due some figure 8s
Old Jan 30, 2011 | 09:51 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
tire might be too big if it has rims on it
Old Jan 31, 2011 | 06:26 AM
AndyD's Avatar
Will check out your suggestions and let you know outcome--thanks guys!!!
Old Jan 31, 2011 | 09:19 AM
RA72825's Avatar
Do you feel this "rubbing" noise when you are in reverse and turning as well? If so, take Socketman's advise and have the dealer change your transfer case fluid and hope for the best.
Old Jan 31, 2011 | 12:46 PM
AndyD's Avatar
Checked PS fluid--it was good. Of course, when I went outside this morning to follow up on your suggestion of checking to see if it will do the same in reverse--nada. Can't reproduce it. Took it to the nearby K Mart and did enough circles to the left and to the right that I was starting to draw a crowd. lol
Will keep an eye on it. As usual--you guys are tops!!!! Many thanks
Andy
Old Feb 4, 2011 | 05:26 PM
AndyD's Avatar
Rubbing did come back--dealer said needs transfer casing flush---right on gentleman!!!!
Just like socketman suggested!!!!!
Will be bringing it in Tuesday so they can do the work!!!!
Old Feb 9, 2011 | 10:10 PM
AndyD's Avatar
Socketman--you were spot on dealer flushed transfer case--rubbing all gone---!!!!
Old Feb 10, 2011 | 03:46 PM
RA72825's Avatar
Good job paying attention to what your E500 was telling you and getting it taken care of rather than waiting until it developed into a blown transfer case. Enjoy!
Old Feb 10, 2011 | 04:32 PM
AndyD's Avatar
Key as you can see the family has 3 MB's I am a backyard mechanic from the old days--points, plugs, condenser, dwell etc. I do as much work as I can on the Benz's, but the first place that I look to is this site.
You guys told me what the problem was before the dealer even saw it!!!!
I have to give the dealer credit---it was not a Benz dealer--no problem--we will order the fluid and bring it back. No charge--wish more people were like that.
Once again thanks for the into and help.
Old Feb 10, 2011 | 08:38 PM
socketman's Avatar
r
glad to help
Old Mar 28, 2014 | 12:23 AM
norpcom's Avatar
2004 MB CL600 ; 2007 Mercedes E550 4matic; 2009 Dodge Challenger SRT8
rubbing chattering
I'm having the same kind of rubbing / chattering noise. Took it to the dealer and the said they had to align something. Noise went away for a bit but its back now. Dealer said the transmissions and transfer case are all one unit on the e500s... if so would changing the transmission fluid fix this issue?
thanks
Old Mar 28, 2014 | 11:47 AM
konigstiger's Avatar
'71 Pinto
Dealer should check to see if vehicle is included in Service Campaign (covered out of warranty) affecting MY 05-07 203/211/220 4matic (see link) http://www.benzworld.org/forums/w220...ml#post5902434 If not, replace TC oil. If problem persists and within VIN range, may need to replace with modified TC – see bulletin (covered under extended warranty). No warranty, if vehicle is regularly serviced by MB dealer, request goodwill assistance for replacement since MB released modified part to correct known problem.
File Type: pdf
Old Mar 28, 2014 | 07:33 PM
norpcom's Avatar
made an appointment to take the E500 in on monday. before I do, I decided to look at my VIN. It's in the effected range. So being curious, I looked at my transfer case and it's serial is PRE affect range for the service campaign (my TC SN is 086467). However my problem is identical to the description. So I know the service bulletin applies but unsure of the service campagin.
