Steering Wheel Vibrates When Braking at Low Speed
I am recently experiencing steering wheel vibrating at the low speed braking. I have searched the forum but could not find any similar symptoms. I have replaced front rotors and pads about a year ago. I also replaced the famous lower balljoints about 6 months ago and put 4 brand new tires and alignment about 4 months ago. The latest was the front thrust arms replaced about 2 months ago. Now I noticed the slight vibration at the steering wheel when I apply the brake.
I am wonder anyone here have similar problem. Any advice would be greatly appreciated.
Thank you
Not sure if you replaced them earlier with an OEM product or a cheaper alternative that has failed on you. The rotors would be the first thing I would look at.
I got the OEM spec Zimmermans rotors and the Porterfield R4-S pads.
To eliminate this for sure, take your rotors off and have them turned. If the problem still exists, make sure your wheels are torque on properly (Unlikely, but that can cause weird problems) and that your tires don't have any tread separation. Tread separation can can weird feelings in the steering wheel at low speeds.
Good luck with this one. Let us know what finally fixes it.
Thank you all
One thing, you really should check to be sure they are all torqued correctly, so as they are not overtightened. Just drive by a tire place and see if they will check them all for you. They usually do this for free.
