E-Class (W211) 2003-2009
Too many different part# for Airmatic relay on forum
Old Mar 2, 2011 | 08:27 AM
Henry.d's Avatar
03 E500
Hello,
Searching mb and benz forum for Airmatic realy came up with too many different part#. Which part# is the correct one? some said it is green color. now, I am getting so confused.
Here the list:
002 542 72 19
002 542 26 19
002 542 13 19
I ordered 1 from rm european web site. They sent me the
Hella 4RA 007 791 011
I called to them. They said it is the same as the 002 542 13 19
Could someone confirm this, please?
Thanks,
HD
Old Mar 2, 2011 | 01:49 PM
konigstiger's Avatar
'71 Pinto
0025422319 see attached part list
File Type: pdf
File Type: pdf
Old Mar 4, 2011 | 04:10 AM
Henry.d's Avatar
03 E500
Konigstiger, I have noted that you have always contrubited very accurate and useful information on the forum.
Your help has really saved us a lot of time and money.
Again, thank you very much for information.
HD
Old Mar 7, 2011 | 03:36 PM
Henry.d's Avatar
03 E500
Hello Konistiger,
I have to ask you another question about the relay.
The reason is today I called to Mercerdes Dealer to buy Airmatic relay. It is ParkPlace Motorcars of Dallas, talked to Randy at part department. When I asked him about part#, he told me it is 002 542 72 19 and it is $65 and it is on back order.
I told him about 002 452 23 19, he says, "I don't know, if you want 002 452 23 19, it is $17".
Now, I am even confuser. what is 002 542 72 19 for? on the relay list on your post. It says, "Pneumatic suspension k76" Am I supposed to change it after changing out Air compressor? What is the location for it?
The reason I looking for the relay because I just changed out the air compressor.
Also, another confused situation for me is the orginal relay in slot S in the SAM in my car is Hella relay, part# 002 542 13 19 with Mercedes logo on it, and made in Spain.
Many thanks in advance, Konistiger.
HD
Old Mar 7, 2011 | 04:48 PM
'71 Pinto
I would base my purchase on part # found in vehicle, 0025427219 replaces original 0025421319 installed at production. BTW, what leads you to believe it is the relay and not fuse f74 (40A) @ front prefuse panel?
File Type: pdf
Old Mar 8, 2011 | 10:24 AM
Henry.d's Avatar
03 E500
I am not the first owner. That is the reason why I don't trust the original relay part# as the people often play with it.
I just changed the compressor and want to change the relay and fuse as recommendations.
The original compressor stopped working b/c the air hose was broken and the compressor just sucked all the dust in bypassing the air filter.
Germany car makers are famous about their plastic and rubber parts.
On your relay list, It has both
002 542 23 19 Airmatic slot S and
002 542 13 19 Pneumatic suspension K67, replace by 002 542 72 19
Why is that?
Is Airmatic = Pneumatic suspension?
Should I go with 002 542 72 19 or 002 542 23 19 or 002 542 13 19?
On the forum, most people talking about the after-market Hella 002 542 13 19, made in china.
Does the relay part# depend on car VIN# or year make or model#?
Thanks,
HD
Old Mar 8, 2011 | 11:53 AM
'71 Pinto
I agree you should replace associated relay when replacing malfunctioning compressor. Spoke with several parts managers and all concur 0025427219 is correct for your 211.070 unknown why both part #s reference Airmatic - your call OEM (parts.com $31.62 or getmercedesparts.com $34.50) or aftermarket (autohausaz.com $14.17) my recommendation - OEM.
Old Mar 11, 2011 | 10:35 PM
arshadkhan's Avatar
2003 Mercedes E320
Airmatic relay part number
Hey henry what part number did you used cause i was confused too. i have 2003 E320 and i called mercedes and gave them my vin# and the part number they gave me is 002 542 7619 which you do even have listed. also the cost was $10 from them. The website i order is from is genuinemercedesparts.com
Originally Posted by Henry.d
Hello,
Here the list:
002 542 72 19
002 542 26 19
002 542 13 19
Thanks,
HD
Old Mar 14, 2011 | 11:59 AM
'71 Pinto
EPC shows 0025427619 as starter relay for G400CDI, not listed on e320 relay list correct OEM part for your e320 is 0025427219. See post 5 to identify location.
File Type: pdf
Old Mar 5, 2013 | 10:30 PM
abbythird's Avatar
E320 2002
konigstiger,
Can you post the Prtlist and SAM Relay for E350 2006 base model? I have an Air Injection Pump bad and I need to replace Relay and fuse as well.
Old Mar 6, 2013 | 11:16 AM
'71 Pinto
See post 2, R relay - fuse is f61 (40A)
File Type: pdf
Old Mar 17, 2013 | 05:35 PM
abbythird's Avatar
E320 2002
Originally Posted by Plutoe
Don't be lazy suscribe to EPC, it's free, and you will learn many things about your car
What is EPC?
Old Mar 17, 2013 | 05:36 PM
abbythird's Avatar
E320 2002
Thank you konigstiger!!
Old Mar 17, 2013 | 05:58 PM
abbythird's Avatar
E320 2002
Konigstiger,
My SAM box R-relay doesnt show the p/n. Please see the attached picture. Is the part (with the red arrow) right?
Old Mar 18, 2013 | 01:03 PM
'71 Pinto
Yes, this is R relay part # 0025421319 for e320 see post 9.
EPC = MB parts catalog https://mbworld.org/forums/2518219-post1.html
Old Mar 18, 2013 | 01:48 PM
abbythird's Avatar
E320 2002
how come my doesnt show the p/n on the relay? but show ++0446
Thanks again!
Old Apr 12, 2013 | 09:10 PM
99clk320's Avatar
2005 E500 4Matic
Hi all. I know this question has been beaten to death, but i'm still confused. For my '05 E500 4matic, autohauzAZ only has 002 542 26 19 (Hella OEM), which is a 4 prong "multipurpose" relay. It is the only one they sell and looks exactly like the 002 542 13 19 that is the "correct" part number. http://www.autohausaz.com/search/pro...nation%20Relay
I ordered it but am now hesitant to try it. Does anyone know if it will work in place of the other part number given that it looks the same and is "multipurpose"?
Old Apr 14, 2013 | 06:20 PM
99clk320's Avatar
2005 E500 4Matic
Thanks Plutoe. I figured as much. Been having getting some errors subscribing to EPC using the link above but will try yet again.
