DOES YOUR W211 HAVE A CONSIST VIBRATION? READ THIS
**The right motor mount is easier then the left motor mount.
**The left motor is not as easy as the right because their is a few things in the way
**Zero vibration in the cabin. "i honest dont know when the car is on" - so if you w211 v8 is not this quiet something is wrong.
**I saw a few listings on ebay of 2 mounts for $100 but didnt want to take chances with the quality of them
**My car is a V8
Coming from a VW Passat, when I purchased my E350 I was surprised that I could "feel" that the engine was running. In my Passat, I had to look at the tach to double check as it was very quiet at idle. Having said that, the vibrations in the Benz are not horrible but they are there.
Can other E350 owners please comment as to whether or not you get that "don't know the car is on" feeling?
Could engine mounts fail with only 45K miles on the car?
it's like a given gggrrrrhhhhI've had to replace my motor mounts twice now and the car has less than 83k miles
I just bought Febi for my 320 from Pelican Parts for $95 a piece and will probably do them this Friday. Also check control arm front bushing/bearing as those are also hydro bushings and go fast.
This has to do with the fact that the 18" wheels require tires with a smaller sidewall. Because of the weight of the car, they tend to develop bulges in the sidewalls. In addition, there is much more stress put on the wheels and they bend or crack. Apparently it's a rather common problem and people have tried to have MBZ cover/recall the damaged wheels but apparently MBZ has always responded that the damage is caused by people driving over potholes. I think these are the threads I read:
http://www.worldlawdirect.com/forum/...t-vehicle.html
https://mbworld.org/forums/e-class-w...careful-2.html
It is the 20 mm of rubber you put on them that is not giving necessary cushion and that is where quality of rims and quality of tires plays big role.
Our wagon runs on 18" Lorinsers and they are good wheels.
I just replaced MM our wife W211 E320
Surprisingly it come much easier than on W210 with the same engine. I was done in 1 hr still answering the phone in the mean time.
Can't wait for longer drive on Sunday to compare the vibration.
