E-Class (W211) 2003-2009
Limp home mode B5/1 sensor or Turbo!?
Old Jun 22, 2011 | 02:10 PM
I_Need_Help2's Avatar
E270
Hi All,
and sorry if you see this on another forum but not getting any replies there!
I have a w211 2003 E270 that has an intermittent issue, but I have found a way or causing the issue almost at will! issue is as follows:
When the car is cold I floor the accelerator and within 200-300 yards the car goes into limp home mode! no power very slow acceleration.
No lights come on and to reset it I just stop the car and restart it and all is fine again.
If I drive the car with say less then 50% throttle for the first mile or 2 there is no issue, I can floor it no problem thereafter.
I have a cheap EODB reader which shows no codes.
I took it to a non merc deal for its service (100K miles) and they said it had code PO105-001 sensor B5/1 over voltage. they cleared the code and I drove the car less then 300 yards and got the problem to happen, I returned to them and the code was showing up again.
So what do you all think? is it the B5/1 sensor (if so where do I find this and can I do it myself? and pics anywhere? is this the MAP sensor by another name?)
or I have also a found post that say:
VNT turbocharger stuck (grabs) briefly,
P 0105-001: Boost pressure overshoot exceeds measuring range of boost pressure sensor B5/1
whatever the above means!!??
Old Jun 23, 2011 | 06:51 AM
morten's Avatar
220 cdi w212 t 2014
hey
i have e 220 cdi it did the same , limpmode, it was the egr valve . i tryed first the maf w/o sucess . after egr repl all ok ) morten
Old Jun 23, 2011 | 12:24 PM
Ichabod's Avatar
1991 F-150, 1976 912E, 2006 E500 Wagon
The bigger question is:
Why would you want to abuse your machinery so badly by not giving it a few minutes to warm up before you use more than half throttle?
Old Jan 18, 2012 | 12:35 PM
E270
Sorry for the very late reply, that's a very long story!
anyway the issue is getting a little more frequent
I will try and find more about replacing the ERG valve thank you for the suggestion.
As for abusing the car, it was happening at near full throttle and worse in cold conditions so I thought I would try full throttle with the car cold and it almost always does it if I do! the issue is that if I need to overtake or pull out quickly I can't as it may drop out on me!
I have also read that if the ECU has been re mapped this could be it, how can I tell if this was done by the previous owner?
As no light comes on is this Limp home mode or just the turbo dropping out? any way of resetting it while going along?
thanks
Old Jan 18, 2012 | 10:43 PM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Thumbs up The Bigger Question Really Is . .
Why would you care what he does to his vehicle?
After all, whose car is it anyway?
He is asking us for help, and you critize him for getting with it when HIS car is not fully warmed up.
Why not try and help him instead of being critical of the way he drives?
Derrel
Old Mar 23, 2013 | 08:11 AM
mercedesbeanz's Avatar
2002 c220 cdi
Hi all, I have a similar bug with my recently acquired 220cdi 2002, I noticed it first went into limp mode after i started using the tiptronic for engine braking, the car over revs or seems to not like change from 4th to 5th gear...no malfunction warnings...egr valve or gearbox problem?
Old Apr 30, 2024 | 05:04 PM
Gazzaoco123's Avatar
Mercedes vito
Did you manage to find out what the problem was mate I've got the same issue any help would be appreciated
Old Sep 1, 2024 | 04:49 PM
trigital's Avatar
W213 All-terrain
Deleted
