Take your check engine light seriousely
While driving the car the check engine light came on one weekend but the car drove and felt just fine and in 2 days the check engine light went away on its own. I made a reservation right away for Monday when the light came on over the weekend. On Monday I hesitated taking the car in because by then the light was no longer on but I am so glad that I did take the car in.
The CEL turned out to be related to the defective engine gear and the dealer knew right away what the issue was as soon as they started diagnosing the issue. I was told on Monday afternoon that they had to order new parts and there was a lot of work involved to replace a part in the engine. I already had a copy of the DTB and verified with the dealer that was actually what they were working on.
I ended up getting the car back Wednesday evening and everything seems to be working fine. So glad I bought my car CPO as the warranty picked up the repair cost. Out of curiosity, I asked the cashier the cost of the repair as it wasn't printed on my no charge invoice and she said it was $4,100
So glad I had the warranty as I would not have expected a car with only about 35K miles to need such a big engine repair.Anyway moral of the story is to to take check engine lights seriously and have it checked out as I might have done further damage driving the car if I ignored the light coming on. The other moral is to I guess try and have a warranty!
The only other defect remaining in my car that I know of has to do with whatever that causes the transmission to lurch as I think I am affected based on my VIN. Anyone have any info/DTB about that issue so I can keep an eye out for that as well?
That being said I sincerely hope there won't be any other issues with the engine of this car. From all the research I've done, the engine seems to be bullet proof with the exception of this one gear issue and I'm glad to have had it fixed under warranty in case I decide to hold onto this car for a while.
Does anyone have the DTB for the transmission lurching issue? That's the only other factory flaw I am aware of for this car...
Food for thought?
as long as your fluid levels remain constant, and you temp levels are good, it is not usually a big problem. get it to the dealer if it doesnt go away in a couple days....
Or you could take the ignorance is bliss approach but if you plan to keep the car for a while, might not be the best way to go...
Not engine issues, but issues (BIG ONE$), nonetheless.
I do believe that one can have serious engine problems (a blown head gasket for instance, or water pump failure etc.) and the CEL light may never come on even though the engine is overheating.
I agree with you that regardless, once the CEL light comes on, there is a fault somewhere, and should be resolved or scanned for more info. asap.
Bottom line - I'm glad you resolved your issue.
Of course I don't know for 100% but I think the "engine gear" is with the engine vibration balancing weight system which is gear driven.
I also agree that the CEL is tied to the emission control systems but could there be a remote chance that the knock sensors on the engine could be used to sense the vibration that improperly driven balance sytem generates? I think this is a bit too far...
I think we both agree that if the light comes on it is best to have the code scanned to find out WHY the light came on. That's basically all I was trying to say...
And yes incidentally the light did come on due to something really awful happening in the engine. Though the CEL had gone away, they were able to scan the code and that's what lead them to diagnose and fix a pretty serious issue. And incidentally the Mercedes DTB pertaining to this issue specifically mentioned the CEL as the symptom to look for so it was very much connected.
Of course -- perhaps the CEL comes on mostly for emission stuff and I never disagreed with that. All I was saying is have the code scanned so you know for sure.
