E-Class (W211) 2003-2009
Aux battery R&R
Old Aug 21, 2011 | 05:02 PM
bobsquad7's Avatar
06 w211 cdi, 05 slk350, R1200GS
Aux battery R&R
Well, . . .the time has come when the aux (under hood) battery was showing signs of near death. The voltage dropped to aprox 10.6 after the car sat for 24 hours.
I read several posts that mentioned using an after-market replacement from Auto-Zone, O'Reilly's etc, . . .
I checked with an MB dealer in Dallas (that usually comes up with a good discount) and was quoted $139.00, which is less that OEM retail ($199.00), . .then went to a local wholesale battery company & got a Yasuka (not sure on the spelling) premium 12ah AMG exact replacement for $59.00.
I use the same battery in my Beemer (motorcycle) and get at least 5 to 6 year out of them.
Anyhow, . . .when I changed it out, . . .I connected jumper wires from the vehicle battery cables to the new battery, which I sat on top of the engine intake cover. Then, I dis-connected the old battery, removed it, and placed the new battery into the battery box, being careful to maintain the jumper wire connections.
By using the jumper wires, I never lost 12V going into the vehicle system and didn't need to re-program any of the pre-set's.
This worked like a charm & probably saved another 30 minutes of re-do. In all, . . .no more than a 20 minute job.
Old Aug 21, 2011 | 08:57 PM
maxi13's Avatar
04 E320 4M Wagon
So after removing the old battery you connected the terminals to the new one w/o removing the jumper wires?
Could you provide a model number for Yuasa?
Old Aug 21, 2011 | 09:42 PM
bobsquad7's Avatar
The battery model is: YTX14-BS & correct spelling is Yuasa. It's designed for motocross type usage (lots of bouncing & banging)
Old Aug 22, 2011 | 07:12 AM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
Originally Posted by bobsquad7
....By using the jumper wires, I never lost 12V going into the vehicle system and didn't need to re-program any of the pre-set's.
Thx for putting this up!
Old Aug 22, 2011 | 11:40 AM
vettdvr's Avatar
03 E500 and Corvette
I did this research about 3 yrs ago and found the replacement batteries. The one you used is on my list.
Old Aug 27, 2011 | 05:54 PM
jgrnslt's Avatar
2003 E320
I just called 1-800-Mercedes and they come out and install it for free.
