E-Class (W211) 2003-2009
Heated mirror defrost speed, differences
Old Aug 31, 2011 | 01:21 PM
SnowCub's Avatar
2013 S350, 2021 GLS450, 2003 SLK32
As the temps have been dropping here, I have noticed a huge difference in the time it takes to defrost (de-mist?) my Driver's side and passenger side mirrors. The driver's side is clear within about a minute of turning on the rear defroster. The passenger side, after 5 minutes, has cleared about 2 inches of the mirror closest to the car, the rest slowly clears up as I drive.
My mechanic pulled the codes and didn't find any errors for the passenger side mirror. Is this normal or is the heating element failing?
Old Aug 31, 2011 | 09:20 PM
ap10046's Avatar
CLS500 M113
I thought it was only the drivers side that had the heating element?
Old Aug 31, 2011 | 10:05 PM
JeffyPooh's Avatar
2017 GLC43 'AMG'
I think the passenger side mirror isn't *auto-dimming*, but I think that both outside mirrors are supposed to be heated.
But I'm not positive.
Old Sep 1, 2011 | 01:19 AM
ap10046's Avatar
CLS500 M113
Mine doesn't auto dim or heat..?
Old Sep 1, 2011 | 08:26 AM
06e320cdi's Avatar
2008 ML320CDI
I ran into this issue as well. I took mine back and the dealer checked other cars in the lot and found the passenger side mirror was 10 degrees cooler than the drivers side when in heating mode. Seems to be designed this way. Doesnt make sense, as my Passat heats both at same temp.
Old Sep 1, 2011 | 09:23 AM
hyperion667's Avatar
2012 CLS63
this is known as a 'white people problems'....
I too am white so this is not a racist comment....
we white's have the most annoying problems don't we??
selecting a language at an atm, waiting for the trunk lid to slowly close.....
etc........
:r olf::rol f:
Old Sep 1, 2011 | 01:56 PM
WEBSRFR's Avatar
Tesla Model S P100D
etc........
:r olf::rol f:
Good one! And what about that front seat not moving back a few inches automatically when you open the door and having to tell your passengers the time because the clock is on;y visible to the driver?
Old Sep 2, 2011 | 06:25 AM
SnowCub's Avatar
Originally Posted by 06e320cdi
I ran into this issue as well. I took mine back and the dealer checked other cars in the lot and found the passenger side mirror was 10 degrees cooler than the drivers side when in heating mode. Seems to be designed this way. Doesn't make sense, as my Passat heats both at same temp.
Well that explains why the computer isn't throwing any codes. Oh well. Guess my Passat spoiled me too
Old Mar 10, 2013 | 01:22 PM
rommelle63's Avatar
04 e320 4matic wagon
I also have the same problem with my passenger side mirror, takes much longer to heat up.
