E-Class (W211) 2003-2009
Please Help: Lock the Key in the Trunk
Old Sep 4, 2011 | 12:06 AM
Tom T's Avatar
2017 E300
Hello All,
I just locked the key in the trunk and the spare key is 400 miles away. Any idea to unlock it quicker than mailing the key to me?
Thank you
Old Sep 4, 2011 | 06:05 AM
Gersh320's Avatar
E320 & X166
There really is no way. These cars are designed to not be able to break into; without doing some damage. Sorry. I did the same thing in my X5, luckily it was in the driveway. Just ordered a valet key and waited a few days to get it.
FYI: I did call at least 10 different locksmiths to come open it. Only one offered to open it without that stupid airbag between the door and roof!!!!! After about 30 minutes of trying, he was not successful.
Old Sep 4, 2011 | 06:07 AM
Television's Avatar
CL500 216
Originally Posted by Tom T
Hello All,
Thank you
Other than buy buying another key from you MB dealer it is not possible
Old Sep 4, 2011 | 08:26 AM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
There's no way. With Keyless Go your car would not have locked with the key in the boot. They should make Keyless a standard feature.
Sorry.
Old Sep 4, 2011 | 04:40 PM
WEBSRFR's Avatar
Tesla Model S P100D
Sorry.
Yeah this saved me a couple of times. I would press the button, it would close halfway and then go up. After a couple of tries I realized the car wa strying to save me from my own negligence
Keyless go is indeed one of my favorite features and I use it daily. So much so the other day after parking my Volvo, I got out and out of habbit was looking for the keyless go button on the handle.
Old Sep 4, 2011 | 06:51 PM
JeffyPooh's Avatar
2017 GLC43 'AMG'
Here's the string trick...
http://www.youtube.com/watch?v=5YJzpaz0tmw
But with the extensive weather striping, I doubt it'll be as easy as it seems in the video.
Old Sep 4, 2011 | 09:07 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
http://urbanlegends.about.com/librar...nlock_door.htm
Old Sep 4, 2011 | 09:27 PM
nickmb's Avatar
2003 mercedes benz e500
there is a way!!
same thing happened to me.
i called a locksmith, he got me in the car.
i then went into the fuse box and took out the alarm fuse.
then reconnected it and pressed the "open trunk button" and unlocked it.
very easy
hope this helps!
Old Sep 5, 2011 | 08:11 AM
Gersh320's Avatar
E320 & X166
Originally Posted by nickmb
there is a way!!
very easy
hope this helps!
Did you get it open?
If they use that air bag, you will never have the same seal on that door again. I hope they didn't
Old Sep 5, 2011 | 02:31 PM
nickmb's Avatar
they sure did use the airbag.
and no issue at all with door.
no problems.
Old Sep 5, 2011 | 10:11 PM
WEBSRFR's Avatar
Tesla Model S P100D
no problems.
What's this air bag method?
Old Sep 6, 2011 | 08:54 PM
JDM_SXE-10's Avatar
2003 E500
Wait, you don't have a button that opens the trunk from inside the car? Are you telling me that I have it as an option on my car?
Old Sep 6, 2011 | 09:37 PM
nickmb's Avatar
yes im sure he does.
but when the alarm goes off and you get into the car. the button becomes inoperative.
so you have to pull the alarm fuse, once in the vehicle.
then reconnect it and voila!
Old Sep 6, 2011 | 10:56 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
fwiw, if you have a TeleAid subscription, there's a free remote unlock app for the iPhone. Works great.
Old Sep 7, 2011 | 01:15 AM
JDM_SXE-10's Avatar
2003 E500
Ah, you learn something new everyday. I did not know that when the alarm has been tripped that it disables the usage of that feature.
Old Sep 7, 2011 | 01:48 PM
nickmb's Avatar
yeah, true that.
sometimes you just gotta learn the hard way.
Old Apr 4, 2013 | 09:47 AM
msc1100's Avatar
08 S550
there is a way!!
very easy
hope this helps!
anyone know where the fuse he is talking about is?
Old Dec 14, 2015 | 12:40 PM
Clrhoney's Avatar
slk 280
How about fuse trick for SLK
Or does anyone know how to get trunk open with a method like this on an SLK
Old Dec 15, 2015 | 02:48 PM
dave2001auto's Avatar
84 300d 2009 e320 bluetec (retired)/, now 2012 E350 4-matic blueefficiency automatic
On my 09 e320 bluetec fuse 8 (in the trunk) is the alarm fuse. If the trunk switch is deactivated, how to get into the trunk to remove the fuse?
Also on the question of the fuses and their location, in the interior fuse box, there is a sheet with the fuse map, consuming unit and fuse number.
Old Dec 15, 2015 | 06:16 PM
Originally Posted by Plutoe
Your metal key will always open the trunk and drivers side door--if the alarm goes off put the key in the ignition!!
Simply double check your manual for all the variations that are available for the CL system!!
The metal key will be attached to the regular fob that is locked in the trunk. I can use an air wedge to open the door but that tool will be also in the trunk.
Old Dec 15, 2015 | 11:01 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I would still try buying 2nd key before drilling.
Old Dec 15, 2015 | 11:16 PM
justonlyjohn's Avatar
2013 C300
call mbrace or dealer assistance. this is what they are there for.
Old Dec 19, 2015 | 02:10 PM
Can MB open the car door and truck remotely like On-Star can?
I really long for the days of the keypad on the door. It was great to leave the key locked in the car or trunk. The limited number of fob's prevents a hide a key.
Old Dec 19, 2015 | 02:22 PM
What's the phone number for roadside assistance in the USA?
Old Dec 19, 2015 | 03:00 PM
Gersh320's Avatar
E320 & X166
1-800-FOR-MERCEDES
