E-Class (W211) 2003-2009
Out of town with check engine light?
Old Sep 16, 2011 | 07:37 PM
MPH 350SDL's Avatar
1991 350SDL, 2006 E320CDI, 1999 F250 7.3L Crew Cab 4X4
I am 225 miles from home and my 2006 E320 CDI has a check engine light on. The car operates correctly and all service/filters are current. I have 92K miles and never had a glow plug failure. I am used to the old sprial wire light giving a warning concerning the pre glow system. Will a failed glow plug turn the check engine light on without the sprial wire glow light blinking or coming back on after start?
I do know that I need to have the code read, but I am not in a position to do that as of now.
Old Sep 16, 2011 | 07:51 PM
vettdvr's Avatar
03 E500 and Corvette
I don't think you will have an issue driving home with the CEL on. Not the oil/temp etc. But do get it checked.
Old Sep 16, 2011 | 08:02 PM
MPH 350SDL's Avatar
Thanks vettdvr.
Do you know if a glow plug failure will trigger the check engine light?
Old Sep 17, 2011 | 02:59 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
is there an autozone near where you are staying? If so, simply walk in and borrow their OBDII/CAN code reader tool. All you need to do is give them your ID as collateral. Why risk not knowing what is going on?
Old Sep 17, 2011 | 08:04 AM
edwinwalke's Avatar
2006 E320CDI
Thanks vettdvr.
It will trigger the CEL but you will also see the Glow plug indicator stay on after start. So if you just have a CEL and no abnormal behavior with the Glow plug indicator it probably is something else.
Old Sep 17, 2011 | 08:37 AM
vettdvr's Avatar
Thanks vettdvr.
Yes but in the owners manual you will find details on CEL and it is a drive you to shop issue.
Old Sep 17, 2011 | 09:18 AM
brm's Avatar
brm
2008 E350 Sport
He's right. The CEL is also known as the "Scare the wife" light. It primarily monitors emissions systems. If there's something seriously wrong, you should get a specific warning, such as low oil level or overheating. That said, if you can get it scanned where you are, it will give you peace of mind.
Old Sep 17, 2011 | 09:48 AM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
Could be dirty diesel?
Old Sep 18, 2011 | 03:03 PM
MPH 350SDL's Avatar
The code was P0269 Cyl #3 contribution balance
I finally got back to civilization and had the code read. "Cylinder # 3 contribution balance" is what the scanner had on the screen. I guess that I probably need to have a contribution test performed? Now that I think about it and look back, I can have a "bumpy idle", but not all of the time. It just briefly comes and goes.
The light did not come on for the last 125 miles of the trip and it has not reappeared with about 6 starts since.
Old Sep 21, 2011 | 05:27 PM
MPH 350SDL's Avatar
Update for #3 injector
After a trip to the dealer, one injector and $689.63 later, I now have a very smooth CDI. I do notice less particulate upon full throtle acceleration and the idle is smooth as glass.
I now know this injector was in failure mode the day I purchased the car. The dealership experience was very positive.
