E-Class (W211) 2003-2009
How to tell if car has xenon headlights?
Old Feb 15, 2012 | 09:06 AM
T100T's Avatar
Top Answer: 1
2010 E550
I'm looking to buy a used W211, probably and 08 or 09 E350 and want to know if xenon lights are installed. Having viewed lots of pictures on eBay, some of which do or do not mention xenons, I can't see a clear difference. Aside from calling MB with the VIN can someone give me a simple way to tell if xenons are installed.
thanks,
Peter
Old Feb 15, 2012 | 09:18 AM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
What is the VIN? I can run it.
Old Feb 15, 2012 | 10:10 AM
06e320cdi's Avatar
2008 ML320CDI
If you can see the front, look for the triangular cutouts between the parking lights and headlights. This will indicate there are headlight washers, which I believe are only available on cars with Xenon.
Old Feb 15, 2012 | 12:45 PM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
There's a good website up that will decode MB vin's for free.
(that said I can't remember what it is, but I did mine and it worked great)
Old Feb 15, 2012 | 09:52 PM
rsmith7's Avatar
Veteran: Navy
2009 E350 Arctic White AMG Sport package W/ P2 option, 2002 C230 kompressor Coupe
Look for premium package II.
Old Feb 15, 2012 | 09:57 PM
Craftysince86's Avatar
W211
think hes trying to do it without the vin...
its pretty easy to tell the difference between incandescent lights and the xenon/HID (High Intensity Discharge) lights
post pics
Old Feb 16, 2012 | 01:38 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
If you look at any xenons at night, you will see the bright, white light. Turn on your lights and compare, and you will see the difference immediately.
Old Feb 16, 2012 | 04:45 PM
el_do33's Avatar
It's not that hard to tell the difference. Directly at the headlighs, the NON-Xenon aren't white at all. Majority of the one I've seen of the E class below 2011 models don't have the package.
I still can't believe they won't put it as a standard with packages in 2012 these days.
Old Feb 16, 2012 | 11:53 PM
T100T's Avatar
Top Answer: 1
2010 E550
Thank you to everyone who replied, I was hoping there was going to be simple way to figure out from photo's but it's sounding unlikely.
As others have commented it seems that by 2009 all W211's have the covers below the headlights where the headlamp washer would be. However it seems that most of those covers are really just blanking plates and there is no wash feature.
In fact I'm not even sure where the button is for the headlamp washer, does it come on when the windshield washer button is pressed. A while back it looks as though it was next to the light switch but I'm not so sure on the later cars.
It does seem the xenons come with the PII package so I'm going by the rule that if the photo shows the keyless go then there's a good chance it has xenons.
Peter
Old Feb 17, 2012 | 12:02 AM
willy_manilly's Avatar
2012 W212 | 2016 W205
There will be a headlight washer button on the light panel to the left or right of the steering wheel.
Old Feb 17, 2012 | 09:09 AM
Barry45RPM's Avatar
2015 ML 350
The Headlight washer button was discontinued sometime after the 2007 MY. In those cars, (08/09?) the headlights will be automatically washed every so often (triggered by how many times the windshield was washed I believe.)
(My 07 still had the washer button so of course, my manual has no mention of the no button/automatic spray system's automatic operation.)
Old Feb 17, 2012 | 11:53 AM
JeffyPooh's Avatar
2017 GLC43 'AMG'
Every 5th windshield wash results in a headlamp wash (no matter if it's required or not).
Old Feb 17, 2012 | 03:47 PM
Maddic's Avatar
MB
One way to tell you the car is equipped with P2 or PII package is that you have to have to take a look at the shifter. If the shifter has this button in the middle, it will have xenon!
The shifter above has a push-in button, which mean it starts your start without a key, and I believe this keyless go feature is part of the PII package...
This is a earlier discussed similar topic....go search the forum! https://mbworld.org/forums/e-class-w...ipped-car.html
Old Feb 17, 2012 | 11:32 PM
rsmith7's Avatar
Veteran: Navy
Video
Here is a video showing what you see when you start a car which has HIDs installed. Notice that the lights tilt down and then level back out.
http://db.tt/ShEcqwmZ
Video is from an iPhone and requires quicktime.
Old Feb 18, 2012 | 08:15 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
The poster above is correct. If the car has keyless-go and is 07+ it will have xenon. 2003-2006, headlamp washers were the indicator. Starting in 2007 they started putting washers on halogen cars.
Old Mar 5, 2012 | 05:14 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
I have read in another forum that Sport package included xenon on pre-'07 models, and all xenon models had the headlight washers. But is it possible for an E500 AMG-sports-package car to not have xenon; is it possible to have xenon as a standalone option (without having the headlight washers)? This is so confusing....lol
This is the car in question: http://www.autotrader.com/fyc/vdp.js...standard=false
Old Mar 5, 2012 | 06:06 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
That car has Halogens^
