E-Class (W211) 2003-2009
2009 E350 Tapping Noise Only When Starting Engine
Old Apr 1, 2012 | 02:22 PM
loudbmw's Avatar
17 E300, 17 C300, 14 C250
Slight tapping noise when I start the engine on my '09 E350 with 49K miles. It lasts only about a second and only does it if the car has been sitting for a few hours. After 2 seconds car sounds perfect and if I restart the car no noise unless a couple of hours go by.
Sounds like only one valve is noisy - car has had better than scheduled maintenance with MB recommended oil & filters since day one. Car has never been abused and uses zero oil between oil changes. Any ideas?
Old Apr 2, 2012 | 08:32 AM
vettdvr's Avatar
03 E500 and Corvette
Mine has had some valve tappet noise since new now has 118,000 miles. Make sure you are using correct MB approved oil and filters.
Old Apr 2, 2012 | 08:39 AM
jcat's Avatar
2017 S550 4matic
if it isn't valvetrain noise, your injectors may be sticky. This can make some noise too. Every car I've had that same noise on (higher mileage typically) I run a bottle of lucas fuel system cleaner through and quiets them right down.
Old Apr 5, 2012 | 12:05 AM
AMGAffalterbach's Avatar
2014 BMW M235i
loudbmw
Garage is empty, add now
loudbmw
bmw
Old Apr 5, 2012 | 08:40 AM
jcat's Avatar
2017 S550 4matic
Originally Posted by AMGAffalterbach
dunno where your post went, but i saw it in my email. To clarify, i'm not talking about removing injectors and 'flushing' them with some kind of cleaner, i'm talking about your typical fuel system treatment added to the tank before you fill up. Just once in a while of course, but I prefer to use the Lucas fuel system cleaner concentrate rather than the Techron. For one, it's cheaper, and one bottle treats up to 20gal so I feel it gives enough cleaner:gas ratio for my usual ~15gal fillup. Gets the water out of the lines, helps clean up some of the carbon in the combustion chamber/valves and has lubricative properties to help keep moving parts in the fuel system moving smoothly.
Old Apr 6, 2012 | 12:20 AM
2014 BMW M235i
Accidentally deleted it. However that sounds interesting, huh I'll have to look into it.
Old Apr 6, 2012 | 09:48 PM
loudbmw's Avatar
So a guy with a Mercedes can't have a Bimmer too?
Lou
Old Apr 7, 2012 | 01:22 AM
MPOWERD's Avatar
2007 W211 E350 Saloon, 2003 BMW E46 M3 Cabrio
Lou
I do!
Old Apr 7, 2012 | 03:02 AM
2014 BMW M235i
Originally Posted by MPOWERD
I do!
Old Apr 9, 2012 | 02:43 AM
MPOWERD's Avatar
I didnt know you were from Cleveland...
Old Apr 11, 2012 | 07:03 PM
mikem's Avatar
07 C350 Sport
Does it go away after reving up a little?
Does it happen all the time? Might be the Gas Purge valve , located in the front of the engine compartment. Drivers side black plastic looking device.
You might take it to your dealer who will have the noise technician (with Stethescope) look at it.
Mike M
