E-Class (W211) 2003-2009
The dreaded M272 Balance Shaft
Old Dec 9, 2017 | 07:32 AM
  #451
Ronald12's Avatar
2007 E320 Bluetec and 2008 C350
Hello, can someone check the vin/ engine number for this 2007 E350? Checking for the potential camshaft failure. Also does this model have the SBC issue?
WDBUF56X07B182992
Old Dec 9, 2017 | 07:41 AM
  #452
jimbo1763's Avatar
2007 E350 Sedan
From what I see, your engine number is 272964 30 666318. Affected engines went up to 30 468993, so you ought to be okay. By the way, you said cam shaft, and this is for balance shaft, but I think that is what you meant.
MB stopped putting SBC brakes in cars in 2006, so if yours is a 2007 you don't have them.
Old Dec 9, 2017 | 07:47 AM
  #453
Ronald12's Avatar
Thanks for the quick reply Jimbo! Yes I do mean the balance shaft.
Anything else pro or con I should know about this model?
Thanks again
Old Dec 9, 2017 | 08:09 AM
  #454
jimbo1763's Avatar
2007 E350 Sedan
My 2007 E350 is going strong at 181,000 miles. I have taken good care of it. Mine did have to have the balance shaft replaced.
Ask if the conductor plate has been changed on the transmission-that is a weak point on a lot of these (mine included). The symptoms are the car hanging in a gear too long and then sudden unexpected shifting. It is about a $1200-1500 repair.
Also check for regular maintenance, including transmission fluid changes every 40K miles. Not sure if you are 4Matic-if so, the same applies to the transfer case.
I assume you are looking at the car-get a thorough prepurchase inspection done, and check the service records. Regular stuff.
Old Dec 9, 2017 | 02:54 PM
  #455
cetialpha5's Avatar
You can just replace the electrical connector when doing the transmission fluid. I just did mine and it was starting to go. It ends up leaking oil from the wires and that ruins the plate. If you get it early enough, the plate will be fine, I think the connector is only around $7.
https://www.ecstuning.com/b-genuine-...or/2035400253/
Old Dec 9, 2017 | 04:28 PM
  #456
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Originally Posted by axl_rose
Hard to tell. We looked the car up in the MB VMI and the last service record at an MB dealership was 2013 with no mention of the repair. I know the car belonged to an owner of a Chrysler dealer so it's possible the car was serviced elsewhere. I've got an OBDII scanner coming tomorrow so, I may scan the car and see if any codes pop. It's also got new air bags too so somebody has been doing some work on it. It's really clean inside and out but, I am not sure if I am willing to risk $8k if I cannot verify the repair .
If it was a dealers car, I bet the work was done off the books, but still worth checking.
Old Dec 9, 2017 | 04:29 PM
  #457
N_Jay's Avatar
Speed sensors on the plate can go also.
Had the connector replaced with each fluid change, still needed a plate (input speed sensor) at about 135K miles
Old Dec 11, 2017 | 12:29 PM
  #458
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
The V8 engines are included in the timing error related issue - but it's not the balance shaft. I'm not sure on the repair cost - but I think it is far less than the V6.
Old Dec 12, 2017 | 03:17 PM
  #459
rpdeleon's Avatar
E350
Hello, I’m new to the forum and wanted to see if someone could tell me if my engine was affected with the balance shaft issue? I just picked up my car from repair and was told it needed replaced. 272964 30 314192 is my engine number. I have an 06 E350.
Thank you!
Old Dec 12, 2017 | 03:35 PM
  #460
jimbo1763's Avatar
2007 E350 Sedan
Your engine is in the affected range. But not all cars within that range have the problem. Are you having your check engine light coming on and has someone read the codes for you?
Old Dec 12, 2017 | 03:38 PM
  #461
rpdeleon's Avatar
E350
Thanks for getting back to me. Yes I just had it checked and the check engine light was on when I dropped it off at the mechanic. From what I was told is there are codes for the timing chain and that according to mercedes there’s been no repair to the balance shaft and that was likely it.
Old Dec 12, 2017 | 03:39 PM
  #462
Shack1's Avatar
06 E350
Thank you!
Mileage? Ownership length?
Old Dec 12, 2017 | 03:45 PM
  #463
jimbo1763's Avatar
2007 E350 Sedan
You might want to post the code numbers as well.
Old Dec 12, 2017 | 03:50 PM
  #464
axl_rose's Avatar
S550
Thank you!
According to the engine number you provided, it would fall into the susceptible category. Get an obdII scanner so you can get the codes from the car.
Old Dec 12, 2017 | 04:07 PM
  #465
rpdeleon's Avatar
E350
Mileage is approximately 133,695. I’ve owned the car since 09/2012 and purchased it from original owner. The codes provided to me are as follows:
P0060
P0272
P0856 - Fixed thermostat
P1200
“Directly from invoice “likely there is a problem with the timing chain or balance shaft timing gear. Cleared the dtc’s and they did not reset at this time. Balance shaft does not appear to have been done via records with MB”
Old Dec 12, 2017 | 04:35 PM
  #466
axl_rose's Avatar
S550
P0060
P0272
P1200
Fault Code: P1200 or P1208 Pending or Stored
Fault codes 0059, 0060, 0063, 0064, 0271, 0272, 0275, and 0276. These fault codes could be recorded as current in the ECU fault memory. If current or pending these codes are caused by a malfunctioning camshaft adjustment solenoid. If you have these codes you should check for oil leak at camshaft adjustment solenoid.
Old Dec 13, 2017 | 03:13 PM
  #467
Ronald12's Avatar
Vin check please?
can someone please help me to determine if this vin numbers are within the affected balance shafts?
WDBF56X97B183607
WDBF56X17B034320
Thanks!
Old Dec 13, 2017 | 03:32 PM
  #468
Ronald12's Avatar
vin number check?
Also possibly one more?
WDBUF56XX7BO64125
Old Dec 13, 2017 | 04:33 PM
  #469
konigstiger's Avatar
'71 Pinto
All showing invalid, enter correct VINs here: https://www.datamb.com/ 272 clean point 30 468993 >, 273 30 088611 >.
Old Dec 13, 2017 | 05:40 PM
  #470
Ronald12's Avatar
Vin numbers
Thanks Konigstiger for the link. Can you give me affected range of engine numbers?
Thanks again
Old Dec 14, 2017 | 11:44 AM
  #471
'71 Pinto
Stay away from 272 engine up to # 30 468992, 273 up to 30 088610.
Old Dec 16, 2017 | 04:54 PM
  #472
Ronald12's Avatar
Balance shaft
Do the 2007 diesel E350 have any the known camshaft issues?
Old Dec 26, 2017 | 11:01 PM
  #473
rpdeleon's Avatar
E350
I had the it checked for oil leakage st the camshaft and there was nothing. I had it confirmed with the MB dealer that my balance shaft needs to be replaced. I brought up the class action and the service manager said I needed to speak with corporate.
I received a call today from corporate basically telling me my engine was not affected by the balance shaft issue and that they will not offer a good will repair on the balance shaft.
Any other suggestions that may get them to budge?
Old Dec 27, 2017 | 01:54 AM
  #474
Shack1's Avatar
06 E350
That sucks, how many miles?
Old Dec 27, 2017 | 01:58 AM
  #475
rpdeleon's Avatar
E350
134k roughly
