E-Class (W211) 2003-2009
The dreaded M272 Balance Shaft
Old Mar 18, 2014 | 10:14 AM
  #76
kponti's Avatar
E63
How does this 2007 E350 fare in this epidemic? Thank you before hand
WDBUF56X77B010782
Old Mar 18, 2014 | 11:11 AM
  #77
konigstiger's Avatar
'71 Pinto
Early production delivered 7/06, 30 424280 is within affected range – 272 clean point is 30 468993 (as of 10/06 production).
File Type: pdf
Old Mar 18, 2014 | 01:07 PM
  #78
kponti's Avatar
E63
Thank you and I'll be staying away from that vehicle
Old Mar 19, 2014 | 09:52 PM
  #79
vastcre's Avatar
none
I'm looking at a 2006 e350 with 62K miles, VIN#WDBUF56JX6A809584. Will the balance shaft be a problem for me. Also, thank you so much for providing this information.
Old Mar 20, 2014 | 11:57 AM
  #80
'71 Pinto
30 081542 is within affected range.
File Type: pdf
Old Mar 22, 2014 | 06:47 PM
  #81
mumpsdba's Avatar
1960 Biscayne
Could someone please check my vin?
OK - so it's my first post and I am already asking for help (sorry). We plan to pull the trigger on a 2007 C280 tomorrow. It's for my daughter and we really don't want to be bitten by this balance shaft issue. If someone in the know could help us out I would really appreciate it! Thanks, Steve.
VIN = WDBRF92H57F851584
Old Mar 23, 2014 | 12:35 AM
  #82
'71 Pinto
30 417830 is within affected range.
File Type: pdf
Old Mar 23, 2014 | 05:53 AM
  #83
mumpsdba's Avatar
1960 Biscayne
Thank you!
Good to know and I think we will move on and keep looking. The shame of it is this particular car has only 7200 miles on it.
Old Apr 2, 2014 | 12:30 AM
  #84
big lebovsky's Avatar
2008 ML 350
Hello guys...I own 2008 ML 350 with 60K on ODO, and few weeks ago CEL started to coming on and off. Upon visiting MB service, engineers have told me that codes 0064 & 0272 are reason for CEL activation and their advice is to replace all 4 camshaft adjustment solenoids (although only two were faulty: left exhaust - code P0025, and right intake - code P0012).
After reading all your posts I'm afraid that could be just beginning of much worst problem - balance shaft issue. VIN number is 4JGBB86E48A320881, so please could somebody tell me does my engine is within bad range...Mr. konigstiger maybe ?
Old Apr 2, 2014 | 11:17 AM
  #85
bellevue18's Avatar
Honda Odyssey
R 350 question
Hi there, newbie here too. Have tested this R350 2006 with 158k and it looks in pretty good condition. Could someone help to enlighten me on whether this vehicle is affected?
VIN = 4JGCB65E86A002933.
Many many thanks in advance.
Old Apr 2, 2014 | 07:01 PM
  #86
coopershawk's Avatar
2007 C280
I'm looking at another 2007 C280 and would appreciate a review of the following VIN:
WDBRF92H57F889008
Thanks in advance! You can't believe how valuable your comments are and they are deeply appreciated!
Old Apr 3, 2014 | 09:44 PM
  #87
MBNUT1's Avatar
2010 E350 4Matic
I know that this is a W211 but can you check to see if the SL550 has the effected engine WDBSK71F37F125630
Old Apr 4, 2014 | 09:57 PM
  #88
2007 C280
konigstiger...where are you? Your customers are lined up!
Old Apr 4, 2014 | 10:58 PM
  #89
LemonSqueezy's Avatar
14 550 sedan
If you want to see your data card you will have to PM konigstiger for that. For anyone that would like to see their engine number and car info, PLEASE help yourself to this link. It will save you a lot of time. Simply enter your VIN number, click "English", and select "Check". Affected cars are generally in the 2006-2007 model years, but not always.
http://carinfo.kiev.ua/cars/vin/mercedes/
I went ahead and looked up the last 4 VIN's just posted here.
ML350 4matic
4JGBB86E48A320881
Affected up to: 30 468993
Your engine: 30 709628
Not affected.
R350 4matic
4JGCB65E86A002933
Your engine: 30 141394
Affected.
WDBRF92H57F889008
I thought only the m272 (350) or m273 (550) were affected but I could be wrong. But this is your engine number anyways 272941 30 516347.
SL550
WDBSK71F37F125630
Affected up to 30 088611
Your engine: 30 058902
Affected.
Old Apr 5, 2014 | 09:37 AM
  #90
2007 C280
Thanks LemonSqueezy...I appreciate it!
Old Apr 5, 2014 | 09:43 PM
  #91
MBNUT1's Avatar
2010 E350 4Matic
ML350 4matic
4JGBB86E48A320881
Not affected.
R350 4matic
4JGCB65E86A002933
Affected.
SL550
WDBSK71F37F125630
Affected.
Awesome! Way better to know how to fish than to be handed a fish and have to beg for another one.
Old Apr 8, 2014 | 11:29 PM
  #92
2008 ML 350
Thanks man...it appears that I'm still within range of faulty cam adjustments solenoids/magnets (all engines with serial < 272... 30 759427)
Old Apr 19, 2014 | 06:50 PM
  #93
spy1's Avatar
1998 C200 & 1984 190E
550 affected up to engine # 30 08861, your # is 30 25507 so you are fine – PM your email address if you want a copy of your datacard.
Hi please do you have any idea if the affected engines are only 2006 models, i mean would one be safe buying a 2007 model (i don't know the engine number, someones getting the vehicle for me)
Old Apr 19, 2014 | 09:42 PM
  #94
2008 ML 350
You might need to double check 2007 model. My ML is 2008 model, but manufacture date is Sep 2007...
Old Apr 20, 2014 | 02:13 AM
  #95
spy1's Avatar
thanks Lebosky.
Old Apr 22, 2014 | 12:49 PM
  #96
C250MSR's Avatar
C250 4Matic
Please help
New member here, looking to get some help on a new purchase.
can you please let me know if this engine number:
27291134169789
falls into the category of balance shaft issue?
thanks,
Old Apr 22, 2014 | 01:50 PM
  #97
C250MSR's Avatar
C250 4Matic
27291134169789
  #98
C250MSR's Avatar
C250 4Matic
27291134169789
Old Apr 22, 2014 | 01:52 PM
  #99
C250MSR's Avatar
C250 4Matic
Not affected, you're fine.
27291134169789
Old Apr 25, 2014 | 03:19 PM
  #100
hysbenz's Avatar
2006 e350
Angry balance shaft
So, I'm told today that this (balance shaft) needs replacing/fixing after I just dropped $1382 for central gateway and rear SAM...Also, now have to have audio gateway for radio/cd to work...Help!!
I wanted to know if mine is on the "affected" list. There is so much wrong with this vehicle
Vin # WDBUF56JX6A799820
engine # 30 272 964 072 963
I have read some commentary that MBUS has paid 100% of costs...
My dealership stinks so any suggestions on where to take in Alabama??
