E-Class (W211) 2003-2009
Battery terminal in engine bay
Old Apr 16, 2012 | 11:24 PM
kosmo's Avatar
2009 E350
is there a battery connection in the engine bay?
tks
Old Apr 17, 2012 | 08:05 AM
edwinwalke's Avatar
2006 E320CDI
No battery connection in engine bay. To jump start you need to jump the battery in the trunk. Always connect the positive cable first then the negative cable.
Old Apr 17, 2012 | 09:11 PM
Bluebird1's Avatar
2006 E500 Estate
I have pos and neg jump points in my engine bay.
Neg is on the wheel arch on pass side and pos is on the firewall in a box.
Check your Manual.
Old Apr 17, 2012 | 09:40 PM
edwinwalke's Avatar
2006 E320CDI
Check your Manual.
I did and it said jump the battery in the trunk.
Old Apr 17, 2012 | 11:43 PM
AMGAffalterbach's Avatar
2014 BMW M235i
There is a battery in the engine bay, but it is the auxiliary battery so if you see anything in regards to it don't think it can be used for jump starting or the like - it is also vital for brake performance. The only battery you should interface with is the one in the trunk under the removable carpet cover.
Old Apr 18, 2012 | 03:44 AM
Diesel Benz's Avatar
Check your Manual.
Remember not all cars are the same. Not even all MBs. Not even all 211 body E-class cars. You've got a wagon, the sedan model does not have jump start poles at the engine bay like the wagon.
Old Apr 18, 2012 | 10:51 AM
Bluebird1's Avatar
2006 E500 Estate
Jeez fellas I just said what I have and to check the manual for your car.
Ease up.
Old Apr 18, 2012 | 01:59 PM
kosmo's Avatar
2009 E350
WTF. Looks like the boys in Munich are 1 step ahead.
