E-Class (W211) 2003-2009
Tranmission Oil change
Old Aug 2, 2012 | 09:31 PM
solekeeper's Avatar
A V8
Hey guys, looking to do this procedure on my dads 09 e350.. Googled it, and couldn't find anything..
Can anyone help?
Need all of the info, how many quarts, fluid type etc.. thanks!
Old Aug 2, 2012 | 09:47 PM
06e320cdi's Avatar
2008 ML320CDI
Check subscription to www.alldatadiy.com. Probably have the procedures there.
Old Aug 2, 2012 | 10:24 PM
solekeeper's Avatar
A V8
It seems I have to be a member? No thanks, lol. I'm sure it's somewhere, i'm still searching.
Old Aug 3, 2012 | 01:48 AM
Lefix's Avatar
2003 E500
There's another thread that talks about tranny oil flush. Someone said they got it done at a mercedes dealer for $260 out the door, the oil and filter alone is $120, so getting it done at a mercedes dealer is a good idea. $260 isn't unreasonable.
Old Aug 3, 2012 | 07:06 AM
edwinwalke's Avatar
2006 E320CDI
Unless you have the proper tools you will need to go to the dealer or a Independent MB shop that does have the tools. There is no filler spout on the 722.9 Transmission so the fluid must be pumped in from the drain and the fluid level is checked via SDS.
Old Aug 3, 2012 | 08:24 AM
solekeeper's Avatar
A V8
edwin, thanks for the response..
So basically I would need a pump, and can you elaborate on what an SDS is?
And also, how do I know if the dealer does in fact change the tranny oil? Anyway to check?
Old Aug 3, 2012 | 04:47 PM
solekeeper's Avatar
A V8
Originally Posted by Plutoe
Give us a break----elaborate on the MB SDS-----are you serious--search the web
Not only do you need a pump, but you need special connections to the pan.
Wait there is more!!
Guy, are you serious? I was just looking for a quick answer.
No need to be a douchebag.
Old Aug 4, 2012 | 09:23 AM
vettdvr's Avatar
03 E500 and Corvette
I just pulled the pan, cleaned it, replaced magnet, new gasket refilled. Ok many say not to do it that way but I have only been doing this about 40 yrs now and never had one fail. Doesn't mean it won't but havent had one yet.
Old Aug 11, 2012 | 09:16 PM
Baidy Ba's Avatar
Take it to the dealer or independant MB service. You need proper tools
Old Aug 11, 2012 | 10:22 PM
ozusa's Avatar
2004 E320 4matic Sedan
SDS
Mercedes-Benz Star Diagnosis System (SDS) is Professional Diagnostic Software that allows conducting complete diagnostics of all Mercedes-Benz models.
