E-Class (W211) 2003-2009
Sunroof Problem...
Old Aug 18, 2012 | 08:49 PM
Lefix's Avatar
2003 E500
Sunroof Problem...
So I have this weird problem about my sunroof. It won't close if I press it two clicks (auto close), it will move to the closed position, but then it will back up about 3 inches, like if something was in the way.
I tried doing the re-sync, but that didn't fix it.
Does anyone have any ideas?
Old Aug 18, 2012 | 10:45 PM
eatcake's Avatar
2007 E350 4matic
Happened to me. Have you tried cleaning the tracks?
Take a soft cloth, old t-shirt etc..., and wipe the tracks clean and try again.
I've read that ideally you want to clean and re-lube them but I only cleaned mine and it works fine.
(I feel like I just wrote this exact thing somewhere else )
Old Aug 19, 2012 | 12:39 AM
E55Greasemonkey's Avatar
This place is a joke.
You will need to have the "pinch protection" re-calibrated either at a dealership or by someone who has a Star Diagnosis system.
Old Aug 19, 2012 | 09:24 AM
edwinwalke's Avatar
2006 E320CDI
Same problem here with 06 E320 CDI. Clean the tracks with a Qtip with a mild solvent -- I bend the end so I can get it into the track. Once all the gunk is removed use a light lubricant on the bottom track. I have found that they are very sensative to cold weather -- that is when mine malfunctions. Be careful and not put on to much lub and don't use grease -- a spray on lub works good for me.
Old Aug 19, 2012 | 11:27 PM
Lefix's Avatar
2003 E500
Cleaned and lubed today. No luck.. Guess I'll have to go to a dealer and get the "Pinch Protection" Re-calibrated.. Sigh does anyone know how much this will run me?
Old Aug 20, 2012 | 12:16 AM
It's just a matter of hooking up the computer and performing the process, expect about .5 to 1.0 hours @ your local dealers labor rate.
Old Aug 20, 2012 | 09:15 AM
vettdvr's Avatar
03 E500 and Corvette
.5 x $125/ hr = $62.50 to $125.00 to hook up and read computer.
Old Aug 20, 2012 | 12:00 PM
RENNTECH's Avatar
G63
Youre looking at 1 hr charge at whatever the door rate is.
Old Aug 22, 2012 | 08:32 AM
vettdvr's Avatar
I thought the owners manual had a re learn procedure that basically required open fully then close and hold the button in closed positon for 3 seconds. Check the manual before you pay for even 1 hr dealer time.
Old Aug 22, 2012 | 05:25 PM
Lefix's Avatar
2003 E500
Yeah I tried doing the re-sync but it didn't fix it. The dealer can reset the "pinch protection" or something like that with the star diagnostic system, and I think I'm gonna have to go get that done. Unless there's another way to fix this..
