Dumb E 500 Sport Wheel & Tire Question
My question is this. If my tires are now 245 45 17 will the new 18" wheel and tire setup be taller or the same as I have now? In other words will it fill the wheel well the same or will it fill it more top to bottom?
I don't have at hand the site of a tire size calculator, but I believe that your new tire will have the identical outside diameter of your current tires. That being the case, it should not rub against anything or cause the speedometer to be incorrect. Essentially, you have more wheel and less tire around it. It should occupy the same space in the wheel well.
STK why 18 why not 20?
dorothy and toto!
I am going to replace my 17" Sport Wheels with Styling IV AMG wheels. I am going with 18". I was told if I wasn't going to stagger that the correct size tire would be 245 40 18 and that they would bolt right up with my Sport wheel bolts and that I could use my Sport caps.
The overall diameter of the 245/40/18 is 25.7".
It will be a perfect fit!!
Are you going to buy your new wheels from me??
http://www.miata.net/garage/tirecalc.html
It's like your mission to convince everyone to get 20" wheels LOL. I'm just busting your chops. But as STK said, some of us are more conservative (and older!) and we would get some strange looks having 20" wheels on our MB's. Seriously, do you really drive EVERY day with 20's. I never drove in San Fran. but if the roads are anything like they are here in Long Island / NYC they would last maybe a week!! I typically drive 20-25K per year; I'd be buying wheels monthly!
STK, I just did the same exact thing. AMG syling IV with SO3's. Same lugs and they just bolted on. I would recommend the staggered setup (275-35). Can't rotate though. Are you going to keep these for all year use (all season tire) or use it as a summer setup with a hi-perf. tire? I got mine as a summer setup and will put the stock wheel/tire setup back on in the fall. I'll probably end up buying another set of AMG's with an all season tire
stklaw, I love those wheels. I also want them for my '04 e500. Looks like $489/$519 on tirerack. Is that the going price??
David
I thought they were $439. 18X8 all the way around. I am not staggering.
David,
David
Have you gotten any quotes?
Here is a photo.
https://mbworld.org/forums/showthrea...&pagenumber=21
Have you seen non bright silver? Is there a big difference?
If you are buying OEM wheels from the dealer, they should come with bright silver paint. Perhaps the non-bright silver versions are from aftermarket stores and could be knock-offs.
Part #6-603-1300 (8.0J x 18) and #6-6-03-1301 (9.0J x 18).
