E-Class (W211) 2003-2009
2003 E500 making a whining noise at low and high speeds
Old Dec 29, 2012 | 04:35 PM
Michael S Smith's Avatar
Hello all, I have a 2003 E500 which makes a whiny noise from under the hood(it seems), especially if the vehicle isnt warmed up fully. Sounds like a belt maybe. Seems to be getting louder and more frequent with time or with the colder weather. Car has 88 miles. When I hear the noise, If I slow down to almost a stop, it stops and I can drive again until it whines...eventually, it stops whining after Ive been driving for about 20-30 mins. What could this possibly be??
Thanks in advance for your expertise.
Old Dec 29, 2012 | 04:43 PM
vettdvr's Avatar
03 E500 and Corvette
ok here is a guess.
1) power steering fluid needs to be changed with proper MB fluid
2) possible bearing on ilde pulley or tensioner.
The fact that it 'quits' leads me to think you are having power steering pump whine and should change the fluid.
Old Dec 29, 2012 | 08:41 PM
vettdvr's Avatar
Originally Posted by Plutoe
Why not just lift the lid, start the cold car and listen for the faulty part noise.
Too simple a solution.
Old Dec 29, 2012 | 08:43 PM
ozusa's Avatar
2004 E320 4matic Sedan
Dear Plutoe
I have a flat tire, but only at the bottom. What do you suggest?
Old Dec 29, 2012 | 09:29 PM
Barry45RPM's Avatar
2015 ML 350
I have that whine too. It goes away when the car is warm, and the pitch of the whine does not go up or down with varying speeds. I've been told it is some transmission pump whine.
Old Dec 29, 2012 | 09:36 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Did you accidentally install a supercharger?
Old Dec 29, 2012 | 10:15 PM
Robaustin's Avatar
2016 E400, 2015 GLK 350
I had a similar whine with my 2007 E550. Dealer said maybe idler pulley and maybe transmission pump. It continued to get worse until one day the transmission failed. Turned out two O-rings on transmission ECU solenoids had failed. $1300 later, the transmission worked again and the whine was gone.
Old Dec 30, 2012 | 07:23 AM
vettdvr's Avatar
Another simple solution put the flat at the top.
Old Dec 31, 2012 | 02:33 AM
Barry45RPM's Avatar
2015 ML 350
Verrry interesting.... my car is in the shop again (2 months later) with transmission problems.
Old Dec 31, 2012 | 08:53 AM
vettdvr's Avatar
Pump whine can occur from the transmission pump driven by the torque converter main drive in the front of the transmission. Wear or bad seals allowing caviatatinn can cause pump noise that will sound like a whine and vary with engine speed as it is a direct couple to the engine.
Old Dec 31, 2012 | 07:03 PM
Barry45RPM's Avatar
2015 ML 350
Turns out, now I need a Valve Body. 60 Full Days left on ELW.
Old Jan 19, 2013 | 06:33 PM
hotbeer's Avatar
2003 m benz e240 elegance
Thumbs up
which of the pulley on the 2003 e240 elegance is the idler pulley and how expensive is the pulley bearings
Old Jan 19, 2013 | 08:47 PM
hotbeer's Avatar
thanks plutoe I will take a close look at it in the morning
Old Jan 20, 2013 | 09:02 AM
vettdvr's Avatar
I replaced my idle pulley about 2 yrs ago with one from AZ. I checked the bearing inside the pulley and the OEM pulley and AZ had the same made in china bearing. Why pay the $50 for OME when AZ at $20 gives you the same "made in china" bearing.
Old Jan 20, 2013 | 04:14 PM
hotbeer's Avatar
the whinning sound is coming from the small pulley just above the alternator pulley is that the idle pulley on the 2003 e240?
Old Jan 20, 2013 | 07:04 PM
adotomov's Avatar
e220 cdi w211
I had a very similar issue with my Merc. It turned out to be the water pump. The best way to diagnose it is to take off the belt and spin all the pulleys by hand. The one that whines, change it. However, taking off the belt might turn out to be a complicated task for someone that never did it, so better go to your favorite service shop.
Old Jan 26, 2013 | 07:21 PM
hotbeer's Avatar
thanks guys, i replaced the idle pulley today however the sound although less intense was still there. the mechanic changed the power steering fluid and since then it has improve significantly.There is still a little sound which the mechanic said will go away in a few days but i am wondering if that sound is normal since it is barely audible
Old Jan 27, 2013 | 08:29 AM
vettdvr's Avatar
If you changed the PS fluid make sure it was the correct fluid for the MB. Also if you changed it but did not flush it and only changed the fluid in the pump do it again. It took 3 times to make mine finally quiet down. I used almost a liter to change it without doing a total flush.
