E-Class (W211) 2003-2009
W211 Fuses, Relays, SAM Modules chart
Old Jan 28, 2013 | 01:33 AM
Kropf's Avatar
2005 E55 Black, 2007 GL450 Carneol Red
After hunting all over for a complete chart of all of the Fuse, Relay, and SAM module details including amperage and locations on my 2005 E55 AMG (W211), and not finding a nice concise chart, I wrote one. I hope you enjoy. (If you have corrections and/or additions, please PM me so I can update the file. Thanks.)
This link points to a two page PDF file which prints nicely for those who want to fold it up and keep it in the vehicle for future reference: http://kropf.net/w211/W211fuses.pdf
For any without a PDF reader, images of the PDF file follow:
Jun 18 2019: I updated the .pdf file to include most relay numbers, and a few other edits.
Last edited by Kropf; Jun 18, 2019 at 01:45 AM. Reason: Updated the .pdf file to include most relay numbers.
Old Jan 29, 2013 | 09:25 PM
J Dubya's Avatar
W211 E550
Saved to computer.
Many thanks!!!
Old Mar 27, 2013 | 10:00 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Props! Of the highest order!
Thanks for your time and efforts.
Old Mar 27, 2013 | 10:15 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Awesome job, I was looking for this when I wired my i/c pump on ign 1 but never found it.
Old Mar 28, 2013 | 08:30 AM
chawkins2001's Avatar
2006 E55 AMG
You the man!
Old Mar 28, 2013 | 09:15 AM
Roverron's Avatar
ML63
I will be using this thanks!
Old Mar 28, 2013 | 02:49 PM
harshybar's Avatar
MY03 W211 E320 Sport
My Sam doesn't have the 53a/b for the lighter. DOH
Old Mar 30, 2013 | 10:36 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Would anyone happen to know if these are the same schematics for the CLS55?
Old Jul 3, 2013 | 04:19 AM
aminis1's Avatar
W211 E240/advangarde (2005)
Thanks, but i can't find which is fuse located for Right hand side signal (located at fold mirror)
Old Mar 3, 2014 | 10:25 AM
2006 E55 AMG
Great help
Old Mar 3, 2014 | 03:13 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Oh man this would have helped when troubleshooting my HID power issue when I checked all of the fuses individually and reseated them, not a huge job just a pain in the a** if you it's your first time messing with electrical on the car. Does this apply to facelift W211s as well has anything changed?
Old Aug 11, 2014 | 02:09 PM
Roydavis's Avatar
2005 E350
Problem with false warning indicator
I have a 2005 E350. The warning system indicates 'check low coolant level'. The coolant level is fine. There is no loss of coolant. The engine temperature stays normal. I have replaced the sensor under the header tank to no avail. The agents say the front SAM unit must be replaced at great cost. Is there a relay or some other component that has failed and could be causing this? Originally the warning came on intermittently but is now on permanently.
Old Aug 14, 2014 | 02:36 AM
biggking's Avatar
2004 E55 AMG; 1991 Previa
The front SAM on the mbz does go out (if you get moisture inside), they all do. Depending on which 'SAM' you have 100-300 USED online. I might have one or 2, PM last 8.
Old Aug 14, 2014 | 03:02 AM
Roydavis's Avatar
2005 E350
problem with warning indication
Thanks for your response. I am in South Africa and this is a right hand drive car. Will yours be suitable and, if so, what would the price be?
Roydavis's Avatar
2005 E350
Thanks for your response. I am in South Africa and this is a right hand drive car. Will yours be suitable and, if so, what would the price be? Also, is the SAM unit the whole fuse box or just the silver module inside it?
Old Nov 3, 2014 | 06:24 PM
Cbublitz's Avatar
E55
Exclamation E211 fuse - trunk not closing or lights
Lights in trunk and auto trunk shut don't work... Checked wiring and the only thing I think it could be is a fuse... I can still open from driver door and from outside trunk just a pain to have to go back in the car to shut the f'in trunk. Any ideas of a fuse that could be checked???
Old Oct 15, 2015 | 01:56 PM
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
sorry if I missed it, but is there a fuse for the interior light for the trunk, or one for the electronic door handle? Those are the two items thtat are currently not functioning properly for me. THanks
Old Oct 15, 2015 | 09:52 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
W211 E55 AMG and non-AMG fuse and relay chart
Since I also saw the post referenced and this post while troubleshooting my E55, here is some additional information for this resurrected-from-the-dead thread. Some of this info is from recent threads, I don't have the details to credit the posters but my thanks to those who posted the information they had.
Harness variations:
Start of production to 20 March 2003, 21 March 2003 to 31 August 2003, 1 September 2003 to 31 May 2005, 1 June 2005 to end of E55 production.
Front SAM:
Position kR in the first document is the air pump (non-AMG) or oil cooler fan relay (E55 AMG model).
Rear SAM:
Position kA in the first document is fuel pump relay (non-AMG) or heat exchanger coolant pump relay (E55 AMG).
2005 and 2006 E55 AMG:
Model year 2005 has the fuel pump relay and fuse located on opposite side of trunk from the rear SAM; only accessible by removing the trunk panel; no access port.
The model year 2006 has two each fuel pump relays in the same location.
Model year 2005 and 2006 air pump relay and fuse are located on opposite side of trunk from the rear SAM adjacent to the fuel pump relay(s).
Early W211 E55's (model years 2003 and 2004) have fuel pump relay and fuse in same location as the 2005/2006 models but the air pump relay is located in engine compartment next to auxiliary battery.
Based on this thread:
https://mbworld.org/forums/w211-amg/...ml#post8984193
Early 2003 E55 appears to have the fuel pump fuse located in the Rear Pre-fuse block. I am aware of one very early production E55 where the fuse was incorporated into the relay housing. This one example is the only one of which I am aware.
Photos attached show location of model year 2005 E55 AMG air pump and fuel pump relay locations and what a bad fuel pump relay looks like.
Attached Thumbnails W211 Fuses, Relays, SAM Modules chart-w211-relay-location-fuel-air-pumps.jpg   W211 Fuses, Relays, SAM Modules chart-20150705-relay-fuse-2.jpg   W211 Fuses, Relays, SAM Modules chart-socket-terminals-old.jpg
Last edited by bbirdwell; Jun 11, 2024 at 08:11 AM. Reason: Updated air pump relay info and model year relay info
Old Nov 25, 2016 | 07:47 PM
FreddyAMG's Avatar
E55 AMG 2005
out side Mirror Fuses
Excellent work , Thank you but I do need the location for the outside Mirrors
somehow they are not functional
Thank you
Old Jan 29, 2017 | 12:36 AM
JohnLane's Avatar
222 S-65
Hey Gents... Command issue... Hoping for pointers.
Command had been working mostly... It would intermittently take a break after operating for a while and then power up later. This went from an hour of no tunes to 2-3 days of no command. Then no Command.
Fuses are all good.
Edit: power through the fuse... Even using a test light with an incandescent bulb so it will pull some power didn't sniff out the fuse that had high resistance on the blade of the fuse sending power to Command. Testing it again with low ambient light... What are these little arcs as I probe the fuse with the test light? Replace the fuse and problem solved.
Ahh the joys of intermittent electronic issues.
Still trying to find source of #4 cutting out with heavy load... Key off and runs again.
Old Jan 29, 2017 | 03:30 AM
hAwX's Avatar
06' Mercedes Benz E350 n E55 AMG
guys!!
which one is for front cigarette lighter?
Old Jan 29, 2017 | 10:45 AM
konigstiger's Avatar
'71 Pinto
Front SAM (engine compartment) 54a – FYI for constant power you can move fuse from 54a to 54b.
Old Jan 30, 2017 | 02:56 AM
hAwX's Avatar
Thanks mate
Old Feb 3, 2017 | 02:37 PM
mgmrk's Avatar
2005 w211
Which one is for headlight washer ? I couldn't find it.
Old Jun 22, 2017 | 02:12 AM
e55nz's Avatar
MB 2006 E55
Thanks for this , bloody life saver
