E-Class (W211) 2003-2009
2006 mb e350 diagnostic code 0756 b6/5
Old Apr 1, 2013 | 06:55 PM
mbe350cme's Avatar
2006 mb e350
i recently replaced my balance shaft as well as the chain guides, the oil pump, both rear and front main seals. this work was done by myself along with another friend who is also a mechanic. now i am geting a code 0756 b6/5 current intake camshaft and hall sensor (the time of the signal value is implausible could this be related only to the sensor because everything was done internally the right way all marks were lined up can someone please help
Old Apr 1, 2013 | 09:05 PM
mbe350cme's Avatar
2006 mb e350
would that be covered under the 1 hr diagnostics fee? i stress again the timing seems right the car cranks and starts but than stalls within a few seconds
Old Apr 2, 2013 | 09:12 AM
801's Avatar
801
2012 E350 4matic Sport
mbe350cme - may I ask you how many miles you had on your 06 e350 when the balance shaft issue popped up? thx.
Old Apr 2, 2013 | 09:22 AM
mbe350cme's Avatar
2006 mb e350
172,000 valves and cylinder pass compression testing timing seems right car cranks and starts and than stalls mb code 0756 b6/5 right intake camshaft position hall sensor is the only code coming up (generic code po341)
Old Apr 2, 2013 | 09:25 AM
801's Avatar
801
172k ... is that in Km or actual miles? thx.
Old Apr 2, 2013 | 06:42 PM
mbe350cme's Avatar
2006 mb e350
miles why?
Old Apr 2, 2013 | 08:52 PM
801's Avatar
801
172k mi on an 06 W211 M272 is quite encouraging.... which is why I asked. If I can get 172k mi on my 2006 e350 ... I'll be happy as can be. thx for the info.
Old Apr 3, 2013 | 06:57 PM
mbe350cme's Avatar
2006 mb e350
ok so i fixed that problem it was the right intake camshaft sensor but the car still cranks starts for a little bit longer and than stalls but now code po336 comes up regarding crank shaft sensor but i replaced that right before the balance shaft went. could the sensor be damaged and need to be replaced again ? what do you guys think
