E-Class (W211) 2003-2009
faulty evaporator sensor in e240 m b
Old May 5, 2013 | 08:24 PM
hotbeer's Avatar
2003 m benz e240 elegance
Hi members ,my ac unit started blowing hot air through the right vent and cold air through the left vent. yesterday it started blowing hot air through all the vents and this is extremely unbearable. I took it to an ac repair company and they said it is cause by a faulty evaporater sensor and will cost $ 700-800.Do you think this diagnosis could be correct and the repair cost is reasonable ? This is a 2003 e240 m b
Old May 5, 2013 | 08:45 PM
otto6457's Avatar
E350
Sounds reasonable but there are some simple tests to confirm it. Do you have a wiring diagram and know how to read it?
Old May 5, 2013 | 09:25 PM
hotbeer's Avatar
thanks for responding so quickly Otto6457. I dont have a wiring diagram but I was told that the entire dash board has to be completely romoved to replace this sensor and also that the system will have to be recharged.
Old May 5, 2013 | 10:30 PM
otto6457's Avatar
E350
Removing the dash is really not that major. I find it amusing when shops make such a brouhaha over the fact that a dash must be removed. It's usually the independents that complain the loudest about dash work because most technicians have a natural aversion to interior work.
I'm not at work tonight so I can't look up the parts and labor costs, but $700.00 sounds reasonable for parts and labor if the evap temp sensor is bad. I have my doubts about the diagnosis but I'm in no position to tell you it's wrong. My reservation is that an evaporator temp sensor is a simple solid state thermister that seldom fails. Usual failures are damage from incorrect voltage application during a poor diagnosis, or physical damage. Not saying they never fail, but it is unusual. Your description sounds more like low refrigerant in the system. It's not uncommon for a system to lose refrigerant which causes uneven cooling of the evaporator assy. Which in turn can cause different temperature air to come out of different vents. Also, an evaporator temp sensor failure tends to display itself as normal cooling when the system is first turned on. Then the air temp gradually rises and airflow from the vents decreases. This occurs as the system won't control the temperature of the evaporator, allowing the temp of the evaporator coils to drop below freezing. This allows the condensation on the coils to freeze, which causes the air flow to slow down and finally, being restricted by the freezing so much that the air feels warm with little volume. Again, I'm not saying that the evap temp sensor is 'not' bad. I'm saying the symptoms don't make me think of the temp sensor first.
I will add that the shop simply evacuating and recharging the system might have solved your problem. Selling you an evap sensor which would require an evacuation and recharge anyway tends to hide a less than professional diagnosis. A voltage test along with a pressure test would prove the diagnosis.
If you trust the repair facility then you should take it in since the price quoted for the evaporator temp sensor (parts and labor) seems reasonable. (depending on the shop's labor rate and flat rate for the job) If you have doubts, get a second opinion from another shop.
Good luck
Old May 6, 2013 | 02:36 PM
hotbeer's Avatar
Thanks again Otto6457, your explanation is quite logical and I am definately going to seek a second opinion. I will let you know the result when it is corrected
Old May 7, 2013 | 08:31 PM
hotbeer's Avatar
thanks Plutoe, you said removing/replacing the cover below the ic.Where is that located or are you refering to the ac control unit in the dash?
