E-Class (W211) 2003-2009
My 2007 E350
Old Dec 18, 2013 | 01:56 PM
nevillelin's Avatar
2007 MB E350
My 2007 E350
Can some one pls help figure this issue I am having with my E350. Some times when I put my car on drive, it doesn't accelerate correctly, it will give me a very high gear sound,but it does not move gears. I have to turn it off and re start it for it to start moving into different gears. Dunno what the problem might be.
Old Dec 18, 2013 | 02:18 PM
yxc145's Avatar
2004 E320, 2006 Audi A6, 2008 C350 W204, 2010 BMW F10, 2012 Porsche Carrera S 991, 2014 E350 W212
2007 E350? Isn't that a W211 model?
Old Dec 18, 2013 | 11:18 PM
boltonblue's Avatar
15 AMG S63 4-matic coupe
it is a w211 but it sounds like it slipping into limp home mode.
You need to run he codes to figure out why.
Old Dec 19, 2013 | 05:51 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
moved to correct forum
Old Dec 19, 2013 | 12:32 PM
nevillelin's Avatar
2007 MB E350
W211
I think so, I don't know what model that car is. I am just tired of all the issues I am having with the car. I thought the E class is the better model
Old Dec 19, 2013 | 01:20 PM
giant330ci's Avatar
09 ml350, 07 e350
I have similar problem. my car was stuck in a gear. I tried to accelerate and my rmp won't go above 3k. I tried to shift down or up manuelly, nothing happen. i have to restart the car to drive normal. Talked to my mechanic, he said it my be transmission control unit or speed sensors or both.
Old Dec 19, 2013 | 10:35 PM
Still_Waters_43's Avatar
E350 Sedan Sport
I just had this fixed on my car (E350 2006). It was a speed sensor issue on the transmission. Replaced was the valve body and the conductor plate assembly ($1700). In my case it cost more than it should because MB has changed the valve body and I had to get a new style valve body in order to sync with the new cond. plate. So, I don't know if that will be the case with a 2007.
BTW My symptoms were exactly the same as the OP.
