Comfort/sport shift button part number?
I've scoured the EPC, and I can't seem to find a listing for the shift mode selector button for my 2004 e500 4Matic wagon. This is the comfort/sport button in the shift console.
I'm assuming the button is dead, as I'm stuck in sport mode, yet the tranny runs and shifts fine.
Any ideas?
Any ideas?
EPC shows the switch banks to either side of the shift console, as well as the airmatic buttons at the rear. the shift console section makes no mention of it anywhere, not even a plug or connector clutch.
AGH.
AGH.
Received 4,441 Likes
'71 Pinto
If button mechanism is working properly, pull the gear shifter cover to check underside electrical connections also part # may be there.
1 Post
SLK230, E55, Trail Jeep
If you need the little round c/s button, which is part of the transmission indicator piece (p, r, n, d) I have an extra one laying around doing nothing. Pm me if its what you need
Well the switches are only in two EPC areas---one group is---group 27 sub 213--part number 70 and you will need the VIN to select the correct part!!
When I can gain access to the car again, I'll pull up the shift indicator cover and see if the wiring is intact. I'm hoping someone just pulled things apart and didn't reconnect the switch wiring.
Yes, it's just the little round c/s button, but I've not yet put a meter on it to determine if it the culprit. Given that the car runs and shifts fine in S mode, it has to be something simple (so I hope)
As some background, I bought this car at auction. It was a repo, but is in very good shape. It had some burnt out tail lights, and the hatch struts were kaput, which I straightened out right away. This is the last thing to fix for now, until it warms up enough to go tearing into the door panel for the lock actuator replacement. It looks like soemone has gone over the car, but wasn't familiar with MBs, and gave up, putting things back together with notable evidence they were apart. Nothing out of place, just subpar reassembly.
The C/S button feels a little off, so we'll see how it measures on the VOM
well, that was quick, and of course, not simple.
Upon pulling the cover, I have a wire connector for the airmatic, and one for the ride height switches at the rear . The C/S switch is part of the gear indicator, with a flat 6 pin socket.
What appears to be missing is the wire and plug for the c/s switch. I can't find an extra wire anywhere inside the shifter mechanism, yet the car obviously has the comfort/sport option, as it has the 5 speed automatic.
The how-to that konigstiger attached in this thread clearly shows the wire, #6 on the right.
I do have two wires that plug into the shifter mechanism on the driver's side front, but I'm assuming these are in the right place already.
A puzzler, for certain
Any ideas?
Any ideas?
After a cursory look at the selector wiring diagram, there appears to be some big differences between what you say you have and what is supposed to be there---very starnge was this a Canadian car----- regardless what is the VIN!!
VIN: WDBUH83J94X121120
Datacard
Ident number: WDB2112831X121120
Chassis
Model:E 500 4MATIC Order number:0 4 704 79676 Delivery Date:031223 Lights:
Enigne Number:113969 30 559309 Transmission:722672 04 971075Engine
Enigne Number:113969 30 559309 Type of Engine:A 113 010 35 44 ETV-BM:
Text:
Extras
Code Text
040U BLACK
044 NEW TELEMATICS GENERATION NTG 2.5
212 BOP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING 221 BSIGN COOLANT/REFUELING - ENGLISH
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY 242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
264 LICENSE PLATE ATTACHMENT AMERICA
265 LINES-NO.PLATE DISCONTINUED
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB 287 THROUGH-LOADING FEATURE 293SIDEBAG IN REAR LEFT AND RIGHT
309 CUP HOLDER
384 TELEPHONE PREINSTALLATION CP HIGH FOR USA
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
423 5-SPEED AUTOMATIC TRANSMISSION
443 HEATED STEERING WHEEL
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
489 AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI-ACTIVE
494 U.S. VERSION 524PRODUCT PROT. F.PAINT -
TRANSPORT VEH.PRESERVATION
530 COMAND DVD APS USA WITH NAVIGATION
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
581 AUTOMATIC CLIMATE CONTROL
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
673 HIGH-CAPACITY BATTERY
690 EMERGENCY SPARE TIRE (MINI SPARE)
704L UNITED STATES (USA)
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
7XXL NORTH AND SOUTH AMERICA
804 YEAR OF MODIFICATION
810 SOUND SYSTEM
819 CD CHANGER
830 AAMARETTA/LEATHER/NAPPA/SEMI-ANILINE
831 AAMARETTA/LEATHER/NAPPA/SEMI-ANILINE - BLACK/ANTH.
844 FOLDING BENCH SEAT IN CARGO AREA INCL. 2 AUTO -
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
875 HEATED SCREEN WASH SYSTEM
910 DYNAMO WITH HIGHER CAPACITY (FFO)
915 FUEL TANK WITH LARGER CAPACITY
919 AIRCON COOLING POWER PACKAGE
955 EQUIPMENT PACKAGE ELEGANCE
986 IDENTIFICATION NUMBER (VIN-NO.)
989 IDENTIFICATION LABEL UNDER WINDSHIELD
M005 VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M113 V8-GASOLINE ENGINE M113
M50 DISPLACEMENT 5.0 LITER
N28 EXCHANGE NOT ALLOWED, BODY/ORDER AS OF OFL W/ PA1
R11LA 17" 5 DOUBLE SPOKE DESIGN
U16 STOWAGE TANK BEHIND REAR SEAT BACKREST
Funny thing, I can't find a match between year and option codes for this car in the EPC. Year of mod 804 seems to be for a 2000 model year.
I was curious if it may be the wrong cover, and the proper part number had some integration of the circuitry, such that the big plug for the airmatic control also linked into the c/s button?
The other possibility I thought of was that maybe there was a jumper wire missing, but that doesn't seem to fit the design philosophy I've experienced.
Datacard
Chassis
Text:
Extras
Code Text
040U BLACK
309 CUP HOLDER
810 SOUND SYSTEM
819 CD CHANGER
I think that you have to many tangents, in any event the gear selector sensor should have the following of seven wires, a four wire and a three wire set, with the three wire set consisting of brown, gray blue and a green yellow----those are the only wires for the USA and Canada versions.
Now that I have the VIN I will double check the correct cover!!
This would be my selection for a part number for the shift module 211 542 05 26 423+494+804
This would be my choice for the paneling 211 680 23 36 423+494+955
OK,
I think mystery solved.
After a closer look, there are two flat pin sockets on either side at the aft position of the plate, with a 4 wire socket in the center. One of these flat sockets is a double pin row, which is where one of the leads was plugged in. The lead itself is a single row, which I then plugged into the c/s indicator switch. Comfort/sport modes now work!
Of course, I forgot to confirm the Airmatic and ride height adj still work, but I'm certain they do. I guess the two sockets are for options I don't have.
The part # on the back of the switch plate reads: 211 821 32 58.
I took some pics, but I don't think they are necessary at this point.
Many thanks for your help and patience with a Benz virgin n00b
